OctaneRender™ Standalone 3.02
Have you tried clean install of nvidia driver?
This works perfectly. Thank youabstrax wrote:Yesterday I forgot to modify the CUDA binary selection to add support for compute model 3.7 (see viewtopic.php?p=279508#p279508) so I did it this morning and made this Windows test build:
https://render.otoy.com/customerdownloa ... st_win.zip
Please let me know if that works for the Tesla K80s or not. Thanks.
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
- enricocerica
 - Contact:
Yes, same problem.smicha wrote:Have you tried clean install of nvidia driver?
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
What error message do you get?lucioing wrote:Hello!
I can't install it, because it need MacOS 10.11 instead of 10.10.4... Any tips?
Thank you
L.
						Hi Marcus"
Here's the screenshot. It say:
"You cannot use this version of OctaneRender 3.02 under this OS X version. OS X 10.10.4 installed. The app required OS X 10.11 or later..."
Thank you
L.
Thank you
L.
							Mac Pro  5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
						- nycjunglist
I'm running OS X Yosemite (10.10.5) and getting the same error message.
							Ryzen 9 3950x | 128 GB RAM | 2x 3080Ti
						It should work with at least Mac OS 10.7. We are using the 10.6 SDK for most of the libraries and Octane itself and the 10.7 SDK in all other cases. Why it doesn't work, I don't know yet, but I'm trying to fix it.pegot wrote:What OS X versions does v3 support? My machine that I use Octane on still has 10.9 so this is of some concern to me.
						I rebuilt the OSX Standalone with a different deployment target configuration. You can find the new download links in the opening post. This new build should run on older versions than 10.11. Please let me know if that works for you or not. Thanks.lucioing wrote:Hi Marcus"![]()
Thank you
L.
