Render Problem
APaisana
Thanks for the great work with this plugin.
I have a little problem, i dont know if it is a bug in my PC or i'm doing something wrong.
This is my first work with octane 3.0 and lightwave plugin
I have a scene ready to render. (image_01)
go to the render panel, set the numbers of frames and in the Output I save a JPEG in a specific folder (image_02)
I press f10 and everything seems ok.
The render ends but there is no image rendered.
What i'm doing wrong?
Thanks a lot,
António
UnCommonGrafx
Is it putting it in a correct location for it to actually save files?
That's the only thing I can think of for what you describe.
Robert
i7-4770K, 32gb ram, windows 8.1, GTX Titan and gt 620 for display
juanjgon
Should be there. As Robert says, perhaps the problem is the output path.
APaisana
Thanks a lot for your help,
I made a simple test scene and works just fine.
Maybe i have to put the output images in the same folder of the project.
In the other scene i have made everything right, i dont understand.
Return to “Lightwave 3D”
