Version 3.03.3-R1 (11.08.2016)
rwalker wrote: That makes sense. I will wait patiently.
It's available now.
zoppo
valters wrote:
zoppo wrote:
valters wrote:Object is not rendering..
Works here.
Thanks. Can you redownload and render it again. Scene updated
Sorry, I saw this just now.
The problem lies in the displacement channel, without it the object renders.
C4D 2025 | Win10
I'm preparing and upload a fix release. Because i have notified a few small issues about volume object for OSX and hair engine about unnecessarily updates. And about material stacking.
Additionaly i have discovered that volume engine and particle engine are not working with "Send All Data" method in render settings. I drop this as a note to manual also. You'll need to fix this on example scenes if i can't reupload soon
I have re-uploaded the latest windows build today(19.06.2016). Previous 3.02-R2 was a bad build with wrong sdk files. My advice to replace your installs with today's build. Sorry for confusions.
useruser
materialstacking: :D
thanks a lot ahmet!
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
useruser wrote:materialstacking: :D
thanks a lot ahmet!
Thanks! Here is a sample scene.
bottle.rar
(2 MiB) Downloaded 345 times
pxlntwrk
I repeat yet but it's always a great pleasure to work with your plugin! Keep rocking ! :D
pxlntwrk.net
Chriz
Hi aoktar,
first: Plugin in generell works really great and stable! Thanks for your work.
second: Stacked Material does not work here. I tried your bottlescene too. Just Glass. Texturepath seems correct.
Win 7 64 bit
2 980Ti
1 780
newest CUDA/Nvidia driver 355.82
Octane Standalone 3.02
Plugin version 3.02 - R2
http://www.C9W.de - Win10 - Dual E5 2620v3 - Display 1 GTX 1080 / Render 1 3090 RTX - 96 RAM - C4D MSA - C4D Plugin version: current - Standalone: current
I have connection problems today. please read my previous message.
after seeing lot of it's not working messages I realised that somebody haven't read notes about limitations.
please find info about it. Works on movable meshes...
the_monkey
Wheres the OSX C4D 3.01 plugin?
This forum page is where the 3.01 plugin points to, but it only provides 3.02.
I need 3.01 because I can't connect to to my networked PC's running 3.01.
What's the last v3 number that works across the network on both platforms with C4D?
-m
Return to “Releases”
