I got a problem everytime I'm at my client's office. They use R17 (with license server) with Win7 64bit and Octane 2.24.
The client's PC is using 2x980tis but I also saw it on other workstations (1xTitanZ, the other 1xGTX770). Newest Nvidia drivers.
What happens is, sometimes the viewport gets really laggy, especially when I have to move the camera. Switching between Alt+LMB and Alt+RMB when moving the camera always results in a 2-7 seconds lag (the viewport just completely freezes and releases again). Its sometimes periodic (every 30-60 seconds) and sometimes every time I want to move the camera. It freezes as soon as I click the button to navigate (be it Alt+LMB or Alt+RMB).
it also happens on non-octane scenes. But when I open the Octane dialog and just press the PAUSE button it gets much better! So I assume it has to do with octane.
Brasco said he thinks its because the CUDA cores are still being used and are not releasing propper, because he has the same problem sometimes.
Anyone else experienced this?
I can't reproduce it on my home office workstation but the setup there is completelly different and not so server-dependant.
Periodic slowdowns / freezes in R17
Check status messages in bottom status line of C4D. Do you notify any output message which reports a generating a preview in this lags? Are you using low priority for monitor gpu?
I have the same here. 1x GTX 970 only for the monitors and 2x GTX 980Ti for rendering, so it is not about the priority.
The system comes to a halt for a few seconds but never crashes. I always thought it might have something to do with some auto-save.
It never occurred to me that this might happen because of OC, but I will test it by removing the plugin while modeling etc. and see if it happens again.
C4D 2025 | Win10
