Is there a way to use a sequence of VDB files?
Best wishes,
Thomas
VDB sequence
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
Hi Sighman,
Thank you for your answer
I can't see the big picture here!? Why would I use a vdb file for a still in Carrara? I usually use Photoshop or Particular for postprocessing when it comes to still images. Is anyone really creating vdb files for stills here?
Best wishes,
Thomas
Best wishes,
Thomas
Hi Sighman,
I saw that you updated the VDB sequence. Great job, thank you
However, could you please try to render the VDB file below in Carrara? It throws an error if I try. Rendering in Octane Standalone works fine...
http://www.openvdb.org/download/models/smoke2.vdb.zip
Best wishes,
Thomas
Best wishes,
Thomas
I found the problem. This VDB file only contains a single grid. You need to go into the Import Settings and assign the Emission channel to 'density' BEFORE you open the Octane Render window. I'll fix this in the next release.tschwenke wrote:Hi Sighman,
Best wishes,
Thomas
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Oh, ok, thank you
