Octane Sketchup Exporter Beta ee [superseded]
TIG
Here's beta.ee
Octane_1022ee.zip
(511.1 KiB) Downloaded 310 times
It has had the coding and html etc radically adjusted in an attempt at MAC compatibility for correctly 'populating' the dialog at its launch.
All users should upgrade - it has been tested on PC, but PC feedback would be appreciated if these changes have broken anything that used to work before [seems unlikely though].
Again MAC feedback appreciated [ :roll: ] - note that there should be a brief delay on a MAC as the dialog first opens - it might briefly show incorrect options checked... but hopefully then it'll revert to the correct 'default' values - this temporary delay is part of the testing... it's as if [unlike the PC] the MAC fails to wait for the dialog to be fully loaded before it attempts the populate it - thereby failing to do it - the short delay tries to avoid this...
TIG
Burkhard
Sorry again...nothings changed.
Sad that I could not help out.
MacPro Quad * 8Gig RAM * GTX 285 Mac Edition ( delete two GT120 to make it run with octane! ) * Snow Leopard 10.6
TIG
It's OK Burkhard ( :cry: )
There must be a fix for this...
TIG
Return to “SketchUp”
