TurbulenceFD & Octane Volume
petrpolyakov
aoktar wrote:Here is some explanations. Samples works on me. Try to play with parameters accordingly this information.
great. thanks. let me try your way.
Aleksei
I have exactly the same problem: the smoke doesn't look good enough. It looks more flat and fake rather than the original render.
RTX 4090 | Ryzen 9 7950X3D | 64GB | Win 11 23H2
petrpolyakov,
This is what i can do with your scene. "Use 3rd party shader" activates the sampling of TFD shaders. So you can get more similar results as TFD viewport/output. Otherwise try to do with Octane Volume Gradient.
petrpolyakov
thanks for the advice aoktar, could you please share the c4d scene you adjusted? so I could look into the settings, sure if it's not a problem. thanks a lot for getting in touch I really appreciate it.
cocobrain
Hello
Have you checked Casey Hupkey NAB 2016 2nd presentation : at 21min he goes through the new Octane volume features with TFD.
he gets a pretty good result by using emission tex & volume gradient in the VOLUME MEDIUM attributes (as oaktar mentioned eralier)
Nevertheless, in Casey's demo, he displays the VOLUME STEP LENGTH feature in the Kernel window to finetune the rendering. But this feature does not show up with me.
I have Octane 3.00 R1.1 + C4D Studio + Commercial version of TFD
Any clue what I could have missed ?
thx
Chris
calus
cocobrain wrote: he displays the VOLUME STEP LENGTH feature in the Kernel window to finetune the rendering. But this feature does not show up with me.
This has been changed during Octane3 beta process.
"Volume step length" is now a Volume medium node attribute.
Pascal ANDRE
cocobrain
Thx Calus !!!
I had just found the VOLUME STEP LENGTH in the Volume Emission Editor....
sorry needs more practice !
Nevertheless, I did a rough test following Casey 's NAB presentation and it works fine
BenjaminH
doesn t work for me .... :(
zoppo
BenjaminH wrote:doesn t work for me .... :(
What kind of answer do you expect with such a post?
C4D 2025 | Win10
Aleksei
Try to decrease the Volume Step Length to a very small value — around 0.1 or even lower.
