I have a problem with the camera. The camera is never synced live. I always have to disable scene sync and then enable scene sync to sync the camera.
Is there any config file, where I might have disabled it in the past?
Camera not synced
What version of the plugin are you using pls? Can you post your plugin Settings screen?
Right now I am using 2.25.0.68. I tried with older versions as well.
This happened with the beta of version 3 as well. My OS is Windows 7 64bit. No difference using Poser Pro 2014 (GD) or PP 11.
I have a 3dconnexion mouse... maybe this has a side-effect?
How do I upload an image? Can I only embed an image from another site?
Allow scaled poser cameras is disabled in the settings.
changing pose of a character isn't synced as well, it is not only the camera that isn't synced live.
Then if you have scaled the camera that is being rendered, the camera will not sync. However I think a warning pops up when this happens.Allow scaled poser cameras is disabled in the settings.
Do you have the Auto Refresh button toggled on?changing pose of a character isn't synced as well, it is not only the camera that isn't synced live.
What does the Octane Log show?
Also, if your camera is parented to anything other than the Universe in the scene, then it will not sync (this is a Poser limitation, which I have reported to Smith Micro).
The camera is neither scaled nor parented. Auto Refresh button is toggled on.
The more I think of it... nothing is synced live, no matter what I do in Poser. Octane only reacts to changes in the scene, if I add or delete something.
What I do:
1. I delete everything from start scene including lights
2. I add 1 infinite light and 1 box from primitives
3. I start Octane
4. Toggle Auto refresh on
5. "Open viewport"
6. move camera with camera controls and move box - no visual feedback in the Octane viewport
7. add ball primitive - and Octane refreshes the scene
Here the logfile:
2016-06-04 11:19:25,150 Python Version : 2.7
2016-06-04 11:19:25,150 Platform : win32
2016-06-04 11:19:25,150 OS Architecture : 64bit
2016-06-04 11:19:25,150 Poser Version : 11.0
2016-06-04 11:19:25,150 Poser App Version : 11.0.3 .32055
2016-06-04 11:19:25,151 Plugin Version : 2.25.0.68
2016-06-04 11:19:25,151 OctanePlugin.py = C:\Program Files\Smith Micro\Poser 11\Runtime\Python\addons\OctaneRender for Poser\OctaneWrapper.pyc
2016-06-04 11:19:25,151 OctaneDefaults.py = C:\Program Files\Smith Micro\Poser 11\Runtime\Python\addons\OctaneRender for Poser\OctaneDefaults.py
2016-06-04 11:19:25,151 Loading Octane library C:\Program Files\Smith Micro\Poser 11\Runtime\Python\addons\OctaneRender for Poser\2-64\PoserOctane64.dll
2016-06-04 11:19:25,151 Paths
2016-06-04 11:19:25,151 C:\Program Files\Smith Micro\Poser 11\Runtime\Python\addons\OctaneRender for Poser\2-64
2016-06-04 11:19:25,151 C:\Program Files\Smith Micro\Poser 11\Runtime\Python\PoserScripts
2016-06-04 11:19:25,151 C:\Program Files\Smith Micro\Poser 11\python27.zip
2016-06-04 11:19:25,151 C:\Program Files\Smith Micro\Poser 11\Runtime\Python\DLLs
2016-06-04 11:19:25,151 C:\Program Files\Smith Micro\Poser 11\Runtime\Python\lib
2016-06-04 11:19:25,151 C:\Program Files\Smith Micro\Poser 11\Runtime\Python\lib\plat-win
2016-06-04 11:19:25,151 C:\Program Files\Smith Micro\Poser 11\Runtime\Python\lib\lib-tk
2016-06-04 11:19:25,151 C:\Program Files\Smith Micro\Poser 11\Runtime\Python\lib\site-packages
2016-06-04 11:19:25,151 C:\Program Files\Smith Micro\Poser 11\Runtime\Python\lib\site-packages\wx-2.9.1-msw
2016-06-04 11:19:25,151 octane.dll: date/time = Fri Jan 22 10:05:28 2016, filesize = 28058184
2016-06-04 11:19:25,153 PoserOctane64.dll : date/time = Wed Jan 27 13:59:12 2016, filesize = 150528
2016-06-04 11:19:25,153 octane.dat: date/time = Fri Jan 22 09:53:52 2016, filesize = 17862319
2016-06-04 11:19:25,153 Current Directory = C:\Program Files\Smith Micro\Poser 11\Runtime\Python\addons\OctaneRender for Poser\2-64
2016-06-04 11:19:25,167 Octane library loaded
2016-06-04 11:19:25,200 addon:__init__
2016-06-04 11:19:27,763 addon:load
2016-06-04 11:19:28,417 init:sceneCreated
2016-06-04 11:19:55,012 ignoring init:objectsDeleted
2016-06-04 11:20:02,098 ignoring init:objectsDeleted
2016-06-04 11:20:23,894 init:objectsRenamed
2016-06-04 11:20:23,894 Ignoring rename of non figure/prop figure Shadow Cam Lite 4 to Shadow Cam Lite 1
2016-06-04 11:21:12,977 addon:render
2016-06-04 11:21:12,983 Opening Setup Window
2016-06-04 11:21:12,983 Opening username from C:\Users\aspin\AppData\Roaming\Poser Pro\11\access.orp
2016-06-04 11:21:13,009 Calling Start
2016-06-04 11:21:16,523 IsActivated returned True
2016-06-04 11:21:16,523 Light 1 set as Sunlight
2016-06-04 11:21:16,621 Octane License is activated
2016-06-04 11:21:16,624 No scene root node set to clear
2016-06-04 11:21:16,624 No rendertarget set to clear
2016-06-04 11:21:16,638 Creating default rendertarget
2016-06-04 11:21:18,414 Converting material Preview from Poser Material
2016-06-04 11:21:18,415 setting Preview to glossy
2016-06-04 11:21:18,418 SavedTreeInfo rebuilt in saveToDictionary. Length = 25
2016-06-04 11:21:18,421 SavedTreeInfo rebuilt in saveToDictionary. Length = 25
2016-06-04 11:21:18,424 init:objectsRenamed
2016-06-04 11:21:18,424 Ignoring rename of non figure/prop figure Light 1 to Daylight
2016-06-04 11:21:46,846 Clearing scene root node
2016-06-04 11:21:46,848 Clearing rendertarget node
2016-06-04 11:21:46,904 Found material Preview for box_1 in saveTreeInfo
2016-06-04 11:21:46,907 SavedTreeInfo rebuilt in saveToDictionary. Length = 25
2016-06-04 11:21:46,911 SavedTreeInfo rebuilt in saveToDictionary. Length = 25
2016-06-04 11:21:46,911 Opening Viewport
2016-06-04 11:21:46,944 Opening Viewport - registering log callback
2016-06-04 11:21:46,944 Opening Viewport - reseting Octane project
2016-06-04 11:21:47,119 Opening Viewport - clearing node references
2016-06-04 11:21:47,119 Clearing scene root node
2016-06-04 11:21:47,119 Clearing rendertarget node
2016-06-04 11:21:47,121 Opening Viewport - reseting progressive save
2016-06-04 11:21:47,128 Opening Viewport - creating Octane rendertarget nodes
2016-06-04 11:21:47,135 Opening Viewport - loading geometry
2016-06-04 11:21:47,135 geometrygroup node created with 1 pins
2016-06-04 11:21:47,135 UpdateChangeManager
2016-06-04 11:21:47,138 total number of vertices = 486, vertex indices = 1536, normals = 486, uvs = 117, uv indices = 1536, polygons = 384
2016-06-04 11:21:47,138 transferring actor box_1 geometry to octane
2016-06-04 11:21:47,138 number of vertices = 486, normals = 486, uvs = 116, polygons = 384, sets = 1536, texture sets = 1536
2016-06-04 11:21:47,142 Mesh node for box_1 created
2016-06-04 11:21:47,142 UpdateChangeManager
2016-06-04 11:21:47,144 creating new objectlayermap node
2016-06-04 11:21:47,144 UpdateChangeManager
2016-06-04 11:21:47,144 Opening Viewport - setting rendertarget
2016-06-04 11:21:47,151 UpdateChangeManager
2016-06-04 11:21:47,167 SavedTreeInfo rebuilt in saveToDictionary. Length = 25
2016-06-04 11:22:05,553 Clearing scene root node
2016-06-04 11:22:05,555 Clearing rendertarget node
2016-06-04 11:22:05,611 Found material Preview for box_1 in saveTreeInfo
2016-06-04 11:22:05,612 Converting material Preview from Poser Material
2016-06-04 11:22:05,612 setting Preview to glossy
2016-06-04 11:22:05,615 SavedTreeInfo rebuilt in saveToDictionary. Length = 25
2016-06-04 11:22:05,619 SavedTreeInfo rebuilt in saveToDictionary. Length = 25
2016-06-04 11:22:05,619 selectPoserSelectedItemInTheMaterialTree.SelectTreeItem for ball_1
2016-06-04 11:22:05,625 EventTreeSelection : node = ball_1
2016-06-04 11:22:05,647 selectPoserSelectedItemInTheMaterialTree.SelectTreeItem for ball_1
2016-06-04 11:22:05,650 EventTreeSelection : node = ball_1
2016-06-04 11:22:05,665 Opening Viewport - registering log callback
2016-06-04 11:22:05,667 Opening Viewport - reseting Octane project
2016-06-04 11:22:05,667 Opening Viewport - clearing node references
2016-06-04 11:22:05,667 Clearing scene root node
2016-06-04 11:22:05,667 Clearing rendertarget node
2016-06-04 11:22:05,667 Opening Viewport - reseting progressive save
2016-06-04 11:22:05,674 Opening Viewport - creating Octane rendertarget nodes
2016-06-04 11:22:05,683 Opening Viewport - loading geometry
2016-06-04 11:22:05,683 geometrygroup node created with 2 pins
2016-06-04 11:22:05,684 UpdateChangeManager
2016-06-04 11:22:05,690 total number of vertices = 486, vertex indices = 1536, normals = 486, uvs = 117, uv indices = 1536, polygons = 384
2016-06-04 11:22:05,690 transferring actor box_1 geometry to octane
2016-06-04 11:22:05,690 number of vertices = 486, normals = 486, uvs = 116, polygons = 384, sets = 1536, texture sets = 1536
2016-06-04 11:22:05,696 Mesh node for box_1 created
2016-06-04 11:22:05,696 UpdateChangeManager
2016-06-04 11:22:05,696 creating new objectlayermap node
2016-06-04 11:22:05,698 total number of vertices = 1986, vertex indices = 8064, normals = 1986, uvs = 2144, uv indices = 8064, polygons = 2048
2016-06-04 11:22:05,700 transferring actor ball_1 geometry to octane
2016-06-04 11:22:05,700 number of vertices = 1986, normals = 1986, uvs = 2143, polygons = 2048, sets = 8064, texture sets = 8064
2016-06-04 11:22:05,752 Mesh node for ball_1 created
2016-06-04 11:22:05,752 UpdateChangeManager
2016-06-04 11:22:05,753 creating new objectlayermap node
2016-06-04 11:22:05,753 UpdateChangeManager
2016-06-04 11:22:05,753 Opening Viewport - setting rendertarget
2016-06-04 11:22:05,789 UpdateChangeManager
2016-06-04 11:22:28,302 Closing Viewport
2016-06-04 11:22:30,617 SavedTreeInfo rebuilt in saveToDictionary. Length = 25
2016-06-04 11:22:30,618 Closing settings window - clearing callback
2016-06-04 11:22:30,618 Closing settings window - saving window locations
2016-06-04 11:22:30,618 Closing settings window - reseting project
2016-06-04 11:22:30,654 Closing settings window - destroying window
What I do:
3. I start Octane
5. "Open viewport"
Here the logfile:
It sounds like PoserPython is not issuing the camera and geometry change events. What other plugins are you running?
