Tiff export in wrong color space and without transparency
FlowFireGames
Hello,
When exporting render passes through the octane render passes dialog, the Tiff export does export in sRGB no matter if linear color profile or sRGB is chosen. Also the transparency is not working, it just outputs a
black background if a multilayer file is chosen.
Exporting a PSD will do it correctly.
Also one thing i noticed, if you export the main pass with the octane dialog over the c4d dialog, the octane dialog has far higher color bleeding on the edges if alpha is used, while the C4D save dialog one is nearly perfect.
FlowFireGames wrote: Also one thing i noticed, if you export the main pass with the octane dialog over the c4d dialog, the octane dialog has far higher color bleeding on the edges if alpha is used, while the C4D save dialog one is nearly perfect.
Check alpha-multiply, it's C4D what does. Control your image's alpha in psd or AE, etc..
