Exporting to Stand Alone
Moderator: BK
bpzen
Can anyone give me some guidance on the best way - if possible - to export a scene with materials form the DAZ Octane plugin to -> Stand alone Octane?
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
linvanchene
Updated:
- added more precise information for animation export
- updated links to lead to the corresponding manual pages
bpzen wrote:Can anyone give me some guidance on the best way - if possible - to export a scene with materials form the DAZ Octane plugin to -> Stand alone Octane?
OcDS System Tab:
OctaneRender export - Complete Scene
- ORBX will create one compressed file including all geometry and materials.
- OCS will create a separate folder with the geometry in .obj form
IMPORTANT: You need to have started rendering with OctaneRender prior to using these export functions, otherwise the Mesh nodes will be blank when you open the exported scene in Octane Standalone.
compare:
https://docs.otoy.com/#60Program%20Overview
For still images:
- use .OCS when you want to work locally with texture files just referenced in their original position.
- use .OCS when you also want .obj to be created in a separate folder
- use .ORBX when you prefer to just have one file for the whole scene
- use .ORBX to share scenes with others
For animations:
Currently .ORBX has some limitations which animated information is included.
- If you only animated OctaneRender related parameters you can use .ORBX
- if you animated poses, morphs, translation, rotation or any other animateable DAZ Studio values use .OCS
- to export animated cameras use the separate options to export Camera Data as .ocs that includes an .abc
You can export animated parts of the DAZ Studio scene separately and combine all the different files with animated data in OctaneRender standalone by dragging pin connections between the nodes in the scene based Node Graph Editor.
Saving and loading .OCS in OR standalone is explained here:
https://docs.otoy.com/#60Saving%20%2F%2 ... g%20Scenes
Using .ORBX in OR standalone is explained here:
https://docs.otoy.com/#60The%20Packager ... RBX%20File
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
linvanchene
For the sake of it I add information how to import the ORBX and OCS in OR standalone.
In OctaneRender standalone the imported DAZ Studio scene files consist of several red "nested group nodes".
This can be a bit confusing at first.
Maybe it can help to read through the official manual section of the Graph Editor first:
https://docs.otoy.com/#60The%20Graph%20Editor
001 exporting ORBX and OCS - was explained in the previous post.
002 Right click - Import
003 Browse to the saved ORBX or OCS
004 imported scene as group node
005A double click the group node to open it
alternatively:
005B right click and select ungroup
006 click on the Default Rendersetting node to start rendering
Update / Edit:
Added information about
Default Rendersetting / Render target nodes
group items / ungroup
in another post:
viewtopic.php?f=44&t=52847&p=278396#p278396
The OctaneRender standalone manual has a lot of very detailed guides about working with the OR standalone UI:
linvanchene
Changes introduced in 3.04.11
From release 3.0.4.11, when you save to an Alembic file, the plugin will also save to an OCS file which contains that ABC file, with all the material connections in place. The OCS file saved to be the ABC filename with a .OCS file extension.
compare:
https://docs.otoy.com/#60System%20Tab
State OR 3.0.20.22
previous post updated to include information to use
- for still images use your preferred scene export option either .ORBX or .OCS
- for animations scene .OCS export
- for animated cameras the separate camera export .OCS with .abc
Veneris
- What is the benefit of export to Standalone? What's better?
- Can I use Octane Render Export (DAZ Studio) and import in OctaneRender Import (Houidini)?
Intel Core i5-2500 CPU @ 3.30Ghz (Quad Core), 12.0GB RAM, NVIDIA GeForce GT 620. Windows 7 (64 bits)
1) It can render vertex motion blur. 2) You can add Volume nodes to render VDB files.
I'm not sure. I know you can export from DAZStudio and import into OctaneRender for Nuke. But unsure of the Houdini import functionality.
linvanchene
Veneris wrote:- What is the benefit of export to Standalone? What's better?
The features that are available in OctaneRender standalone but (not yet) supported in OcDS may change over time.
A huge benefit of OctaneRender standalone is it's scene based node graph editor.
In OcDS you can link the same material to multiple surface zones.
What you cannot do is link just a group of nodes to multiple surface zones while other nodes on the same surface zone remain different.
TLDR version:
The scene based node graph editor is one of the strongest features of OctaneRender because it allows a more time efficient workflow by linking nodes to multiple surface zones or even objects. You just have to update the shared node once to see the result on all linked surfaces or objects immediately.
Example - Creating custom skin materials:
A skin material consists of nodes that are different for each surface like the diffuse and displacement maps etc. But there are also values like specular, roughness, absorption, scattering settings.
If those settings are not identical on all surface zones you will see visible edges where surface zones touch and more importantly there is not a volume created for the skin.
This makes experimenting with skin surfaces challening in OcDS because you have to update each surface zone one after the other with the same settings to see the final result.
In OctaneRender standalone you can simply link 1 node with all the absorption and scattering information to multiple surface zones and you see the result on the whole figure immediately by changing just one setting in one node.
And this goes even a step further. If you have multiple figures in the scene you could link the shared nodes to multiple figures.
Still keep in mind that OcDS offers other unique features like templating, OctaneRender image browser, VRAM management, the ability to animate OctaneRender specific parameters.
I try to perform as much workflow steps in OcDS as possible and then export to OctaneRender standalone for the finishing touches.
Veneris
Understood.
linvanchene
In addtion there are 3rd party tools that actively support OctaneRender standalone:
http://www.phantomtechnology.nl/
Phantom Scatter is a procedural instancing technology for OctaneRender that lets you create amazing scenes with instances in a very conveniant way.
viewtopic.php?f=9&t=33791
Phantom Photo Match is an amazing tool to help you figure out the proper camera settings to match computer graphic elements with photographs.
viewtopic.php?f=9&t=48403
Veneris
Are there more plugins than this?
Return to “DAZ Studio”
