issue: I lost .ies functionality. How restore it?
Guy_frog
Hello everybody,
A few days ago, I tried to use a .ies file provided by a lighting manufacturer. But this .ies file placed in the "Octane Light tag" generated me an error message. I insisted, but every time I got the same error message. I specify that before this, my Octane plugin worked perfectly with .ies files included in the library C4D. And just after this bad .ies file, Octane C4D plugin* nevermore worked with ies lighting! Both symptoms are:
1-There is no longer light if I choose C4D spot light (or ies spot light) with Octane light tag
2- If I create an ies spot with LV, I have only a surface light!
I tested what happened when returning to an old version of Octane plugin but, curiously, the problem persists.
Is anybody have an idea of what I should do to restore Octane.ies lighting function with C4D?
(*note: ies lights still work perfectly with the AR engine ).
Please make a post in standalone section. It's not about plugin itself If there is a problem.
Guy_frog
Hello Ahmet, Ok I'll do this. Thanks, you made me take a step forward when you say me this issue is related to standalone. ;)
You can post this ies file if you wish.
