OctaneRender for Modo 3.03.3 [STABLE]
I am on Windows 10. This would be greatly appreciated if you can do this.
Here is the DEMO version installer for Modo901/2/Modo10, Windows 64 bit, Octane build 3.00. Pls let me know if you have any problems.
https://render.otoy.com/plugindownloads ... t_DEMO.exe
v1adut
plugin authentication problem for the plugin, not on alpha version.
Visualize
Purchased the upgrade. v3 is way more stable and less laggy with huge scenes (billions of polygons). I can even go on the internet at the same time. Also the renders seem faster but I'm not entirely sure.
Thanks for the help.
Edit:
Some features that I would like to see are deferred meshes be compatible with octane plugin as well as "solid uv projection type." Box projection is not wrapping around my model correctly where as solid does. I have a work around for it - quick uv then bake the tileable texture with solid projection. Problem is this is destructive and I can't edit the geometry without having to rebake the solid texture and reapply. With solid projection I can make extrusions and the texture will adapt in the right manner.
You will need to provide more information than this - such as which specific error message you are getting whilst trying to activate, and which specific version of the plugin you are running.
I thought that deferred meshes worked in Modo901 onwards. Which version of Modo are you running? Regarding the Solid projection type - I have had a look at this, and the Box projection, and there are some issues which I will clean up for the next release.
smicha
Paul,
I have a very unusual question: is there any technical chance to code the modo plugin to see scatter nodes from the standalone so that the octane render viewport in modo could display replicas?
Technically - this can be done. The plugin would need to load the OCS/ORBX (from Standalone), and then assign the Scatter transforms to a Replicator particle source.
smicha
Could you code it, please?
I'm sorry - but that's way out of the scope of what an Octane plugin would do - and it's a lot of work for one user's benefit, so not something I can justify when there is cloud support, VDBVoxel, vertex motion blur, Visible Environment, Mesh Ops, etc to implement. You should be able to do it yourself with the new Modo python TD SDK (ie. python can load an OCS, extract the scatter transforms, and assign me to a particle source).
Visualize
Okay so it works for normal geo even with edge weights. But deferred meshes with an xfrog tree are not working in Modo 10 v1. Maybe it has something to do with the alpha card leaves? In 902 sp2 it will load in octane but the leaves are invisible. I was using one of the free pine trees from xfrog.
The trees will function correctly in Octane when they are not deferred meshes. Not a big deal. I can just hide the source mesh and replicate it for a lighter footprint. I will try a vizpark tree later.
MrFurious
@Visualize
I also had a very quick look at deferred meshes in Modo902 with V2.5 of the Octane plugin, and while it seemed to work ok, I opted to use instances for some reason instead (I think it was just easier). Have you tried playing around with 'Display' --> 'Draw Options'? I use this with all my high poly trees and it speeds up openGL IMMENSELY. Can add to your mesh and/or all instances, even with a scene full of high poly tree meshes and instances openGL is still very fast. And enough detail visible for accurate composition in openGL.
Typically I use these settings for a high poly tree:
Which will look like this:
If you need even more openGL speed, uncheck 'wireframe' and things get very fast:
You can assign a different colour/tint to groups of trees for easy visual feedback:
Dino Inglese
CG Artist
Melbourne Australia
Intel Core i7-4820K, 3x GTX 980ti
Windows 7 64bit, Modo 12.2v2 for PC
Octane build 4.04.0.145
Return to “Foundry Modo”
