I was testing octane with new nodegraph and made one material. When I restarted modo I got a material error.
Started logging on 29.05.16 10:07:05
OctaneRender 3.00 (3000020)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'spoiler mesh' (NT_GEO_MESH, 00000002C73F1A30)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'tank mesh' (NT_GEO_MESH, 00000002C78256B0)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'Trunk mesh' (NT_GEO_MESH, 00000002C9AD0740)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'front_doors mesh' (NT_GEO_MESH, 00000002C9ACFFC0)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'rear_parktronic mesh' (NT_GEO_MESH, 00000002C9AD1640)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'back_doors mesh' (NT_GEO_MESH, 00000002AFF12680)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'Roof mesh' (NT_GEO_MESH, 00000002AFF13580)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'backside_mirror_part1 mesh' (NT_GEO_MESH, 00000002AFF11F00)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'Rear_Fender mesh' (NT_GEO_MESH, 00000002AFF13280)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'rear_parktronic1 mesh' (NT_GEO_MESH, 00000002AFF13400)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'Hood mesh' (NT_GEO_MESH, 00000002B5C9CD90)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'Rear_Bumper mesh' (NT_GEO_MESH, 00000002B5C9DF90)
Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'Front_Bumper mesh' (NT_GEO_MESH, 00000002BEDD5060)
OctaneRender for Modo 3.03.3 [STABLE]
I can re-produce this error, and it will be fixed in the next release.Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'spoiler mesh' (NT_GEO_MESH, 00000002C73F1A30)
Thanksface_off wrote:I can re-produce this error, and it will be fixed in the next release.Can't connect node 'carpaint' (NT_OUT_MATERIAL, 0000000014DBB500) to dynamic pin 'carpaint' (type PT_MATERIAL) of node 'spoiler mesh' (NT_GEO_MESH, 00000002C73F1A30)
Hi there is not currently a demo version of the Octane 3 plugin available, however if you let me know if you are on Windows, OSX or Linux, I will put one together for you.Where can I get an evaluation trail of Octane 3 for Modo. I have a Octane 2 license
I've found a way to crash modo on launch and can replicate this 100%, question is if it's just my system or something else. Did not have this problem with v2 tho.
-Launch modo
-Open the octane panel 'Save the current render to PNG or EXR format'
-Leave this panel open and quit modo
-modo will crash on next launch.
If I reset my modo config the problem goes away until I repeat the above procedure.
-Launch modo
Dino Inglese
CG Artist
Melbourne Australia
Intel Core i7-4820K, 3x GTX 980ti
Windows 7 64bit, Modo 12.2v2 for PC
Octane build 4.04.0.145
CG Artist
Melbourne Australia
Thanks for the report - this is fixed in the next release.-Launch modo
Will be possible ctrl Z in octane node graph?
Hey,face_off wrote:Hi there is not currently a demo version of the Octane 3 plugin available, however if you let me know if you are on Windows, OSX or Linux, I will put one together for you.Where can I get an evaluation trail of Octane 3 for Modo. I have a Octane 2 license
I am on Windows 10. This would be greatly appreciated if you can do this.
I will submit this to Otoy as a feature request.Will be possible ctrl Z in octane node graph?
