Perspective Match doesn't match
mbetke
Whats up with the perspective match? Sometimes it works very well, then sometimes not.
Really annoying. Is there something I have to think about? is it a bug?
PURE3D Visualisierungen
oguzbir
max pers. match. some times scales the "virtual camera" (perspective view is can be distorted to match the pers.)
When you match the pers. create a camera from that current viewport.
Select the camera and check it's size (by right clicking the scale button)
if the camera is scaled . Than octane can do nothing to render exact camera.
What I generally do is create the cam from matched perspective viewport.
Than press P where converts the view from cam to a sole perspective view.
Than create camera again from that view.
the camera created may not be identical to the matched view. But at least it renders same in octane..
than you can change the camera to best angle. but do not scale the camera..
use octane perspective correction much as you can.
hope it helps
My Portfolio
oguzbir
if the camera is scaled (like -99, 102, 100 . Than octane can do nothing to render exact camera.
hope it helps
My Portfolio
mbetke
Thanks! I will try. Strange because it works often. Maybe I scaled it by accident. I transformed the "dismatched" render in photoshop sometimes but I prefer a clean render. :)
paoloverona
Unfortunately perspective match with Octane is extremely painful, and I have noticed that, even if different users have pointed out this issue, no solution (seems like no interest) by Otoy's team were found :evil:
I always work with aerial large scale views as I have to match commercial buildings into GoogleEeart or drone photos , and this camera misalignment most of time drives me crazy :(
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
mbetke
I ran into this agian with a building. Loosing another hour to mess around with it.... :( Something that must be finxed!
paride4331
Hi mbetke,
Il issue è già detto da jimstar in precedente post:
viewtopic.php?f=81&t=59207&p=303502&hil ... ve#p303357
Hai tu provato il workaround suggerito da oguzbir?:
viewtopic.php?f=81&t=59207&p=303502&hil ... ve#p303363
mbetke
I see. But with developers changed and 3dsmax getting new versions I thought a simple bugfix could be possible. ;)
Return to “Autodesk 3Ds Max”
