It's texture stacking?!?!
Omg omg omg omg omg omg! I freaking love you dude!
Version 3.00 - R1.1 (25.05.2016)
Yes that's it:) I've been strugling with that for a while. I'm trying to add direct support for that as much as possible.Gumz wrote:It's texture stacking?!?!
Yes right. It creates some complex mixed materials for per objects. Currently it's just possible by using flat/cube/cylindirical/spherical mappings. Also a it's not yet working with material selections.calus wrote:Is it using octane mix-materials queue internally ?aoktar wrote: Yes that's it:) I've been strugling with that for a while. I'm trying to add direct support for that as much as possible.
- mustardseedsg
- Contact:
That's fantastic work, aoktar!
Will it support different mapping styles per material?
Mac OSX 10.12.6 / MBP 15" w Touch Bar, 16GB / Mantiz Venus Thunderbolt 3 enclosure with GX1080 / C4d r19 Octane
- mustardseedsg
- Contact:
Awesome!!!
Is that possible to add to Texture Projection node a Calculate Aspect Ratio button, so the scale will be set matching Image?
And also...can LOCK lock with same proportions as it was unlocked..not 1 to 1 to 1
And also...can you add "s" to the Lock A"s"pect Ratio
If no, then does any know the workflow for that? I just finished to work with 74 images and it was a pain to match it
Hey aoktar.
Is it right, that I can not open my OctaneV3 without Internet connection. I could be offline for some days and this would be complicated.. Just wondering.
had same issue before but now with V3 version you just check (offline) option before you enter the login data. right now my pc is not online but everything works perfectly.momade wrote:Hey aoktar.
