Altus Innobright
Jolbertoquini
Hi Guys,
Just a quick question, I was wondering if anyone have a Lua script to render the passes need for Innobright denoiser,
I'm doing manually is working pretty well but is take a lot time to set then each time, so I was think a way to be automatic as batch render. (only the passes of course :) not the soft I have it already)
Very best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
roeland
You can do something in the lines of:
local rt = octane.render.getRenderTargetNode()
local passes = rt:getInputNode(octane.P_RENDER_PASSES)
-- enable any passes you need, for example direct lighting on diffuse materials
passes:setPinValue(octane.P_RENDER_PASS_DIFFUSE_DIRECT, true)
-- update render
octane.changemanager.update()
Use the “Items” tab on the Lua API browser and find the NT_RENDER_PASSES entry to get a list of possible pin IDs to set.
Roeland
Return to “Lua Scripting”
