I'm not sure whether this is hard coded or if there's an option somewhere. I'm used to working with Octane in LightWave, where I can see updates instantly. Especially handy when I'm working on lighting.
I open the Octane tab and have the Octane renderer to the left, Camera to the right. I start messing with the lighting, and it takes Octane a sec to update. Is there a way to get Octane to constantly update while I'm moving lights or cameras around? I don't mind it being 'low res' while doing so, but it gives a far faster and better workflow to see how things behave on the go.
Octane render viewport lag
Okay, turned out to be only with the sunlight direction.
But now that I've added a point light or a spotlight, I need to refresh the scene manually every time I move or adjust the light.
I'm on Modo 10, Octane 2.25 and 2x Titan by the way.
Modo & LightWave 3D | Win 10 x64 | RTX 2080 Ti | Threadripper 2920x | 128GB
Yes, I agree that not having instant feedback is a limitation, but unfortunately the Modo event system does not issue the "camera changed" call to the plugin until after you release the mouse button when moving the camera - so this is a Modo limitation rather than an Octane plugin issue. Meshes are a little different - and if you turn the Preference->Octane->Use Modo Render Cache ON, then mesh movements are live (if Live Geometry Update is enabled for the Mesh). Be aware there are limitations with the Modo Render Cache - check the on-live doco for details. https://docs.otoy.com/#60Modo901%20SpecificsI open the Octane tab and have the Octane renderer to the left, Camera to the right. I start messing with the lighting, and it takes Octane a sec to update. Is there a way to get Octane to constantly update while I'm moving lights or cameras around? I don't mind it being 'low res' while doing so, but it gives a far faster and better workflow to see how things behave on the go.
Spotlights are not supported - so I'm unsure how you have set this up. Point Lights, Area Lights and Photometric Lights are supported - and the mesh created by the Create Octane Emitter button should follow the parent light and move accordingly - UNLESS you have disabled Live Geometry Update on the mesh, or the light is rigged/parented to something else. In the latter case I intend adding support for rigged light updates in a future plugin release.But now that I've added a point light or a spotlight, I need to refresh the scene manually every time I move or adjust the light.
The octane plugin also has a preference called "update on mouse button release" which is set to default of ON. I always turn this off
Thanks! Let's hope The Foundry figures something out in their API to make a more 'live' experience.
oOps, didn't see your reply.
Where's that?funk wrote:The octane plugin also has a preference called "update on mouse button release" which is set to default of ON. I always turn this off
Further to the above - check out the Preferences->Octane->Update on Mouse Button release setting (mouseover the checkbox for details).
@OlaHaldor I'm also from an Octane for LW background and I know exactly what you mean, the Lightwave-octane interaction is the best I've seen (I've tried modo, 3dsmax, c4d and lightwave) and extremely fast, basically real-time with a decent gfx card and from what I've seen modo-octane simply cannot achieve this. Each package has their pros and cons but I must admit I really miss the interactivity you get with Lightwave.
Dino Inglese
CG Artist
Melbourne Australia
Intel Core i7-4820K, 3x GTX 980ti
Windows 7 64bit, Modo 12.2v2 for PC
Octane build 4.04.0.145
CG Artist
Melbourne Australia
This will allow more 'interactivity' (not what I'd consider to be fluid though) but at the expense of slower openGL performance especially with high poly scenes where it's really noticeable. I posted a thread on this some time ago you might find helpful.face_off wrote:Further to the above - check out the Preferences->Octane->Update on Mouse Button release setting (mouseover the checkbox for details).
viewtopic.php?f=34&t=51614
Dino Inglese
CG Artist
Melbourne Australia
CG Artist
Melbourne Australia
