camera clipping plane
Forums: camera clipping plane
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby WhyGee » Fri May 27, 2016 4:01 pm
WhyGee Fri May 27, 2016 4:01 pm
It seems the near clipping plane is obeyed by Octane but the far clip plane is ignored. Is there any reason/limitation for that?
Yaniv
WhyGee
Re: camera clipping plane
Postby juanjgon » Fri May 27, 2016 4:04 pm
juanjgon Fri May 27, 2016 4:04 pm
Yes, sorry. Octane doesn't have a far clipping plane parameter in the camera nodes. This is why the Houdini plugin doesn't support this feature.
juanjgon
Postby WhyGee » Fri May 27, 2016 4:09 pm
WhyGee Fri May 27, 2016 4:09 pm
What I was trying to do was to render a volume sliced in the middle (front/back) by the clipping plane in order to composite an undetermined middle layer (otherwise would've done a cutout render). I tried rendering a deep image but for some reason I keep running into gpu memory limitations. I have 2 titan X and the volume is rather simple. for deep rendering I need to enable it both on the rop and target nodes correct?
anyways, workaround suggestions would be most helpful.
Thank you
Yaniv
WhyGee
Postby juanjgon » Fri May 27, 2016 4:40 pm
juanjgon Fri May 27, 2016 4:40 pm
Hmm, I am not sure about how to make a slice with a near and far planes in Octane. Anyway yes, the deep rendering must be enabled in the kernel node to be computed, and in the ROP node to write the file. Perhaps you could play with the kernel max. depth samples and depth tolerance parameters to see if this can help with the memory issues.
juanjgon
Postby WhyGee » Fri May 27, 2016 7:07 pm
WhyGee Fri May 27, 2016 7:07 pm
Thanks I'll try
Yaniv
WhyGee
Return to Bug Reports
Tue Jun 04, 2024 12:28 am [ UTC ]
