OpenVDB file sequence.
Godstrike
Hi All,
Looking for some help re. importing a sequence of openvdb files?
I tried $F in the Octane_Volumetrics OpenVDB file dialogue but while the file names scrub through, no data is loaded.
Ryzen 5800x at 4.4GHz | 32GB | 1 x 3090 ti | 1 x RTX 2080 ti
juanjgon
The "$F" token in the OpenVDB file is used to insert the frame number. It uses the #### numbering format, for example, the file "fire_$F.vbd" is expanded as "fire_0023.vdb" in the frame 23.
Godstrike
Hi Juan,
My files are named test_001.vdb, test_002.vdb etc, and when I use test_$F.vdb the data from the openvdb files do not load.
How else do I load a sequence of openvdb files, or am I missing something?
juanjgon
The problem is that your files should be named test_0001.vdb, test_0002.vdb etc ... you need to use a four digits numbering.
Godstrike
Ahh, copy that:) Thanks.
Godstrike
Working perfectly!
Return to “Lightwave 3D”
