plugin problems and displacement (SOLVED)
jelly
Hello, I'm encountering a problem after plugin installation:
1. I have installed the standalone
2. installed the c4d plugin (version 300-R1)
In the consolle Iread this error:
Scene Plugin is older than version 3.00-R1
Plugin will convert the parameters of displacement texture
Animated attributes should be changed manually!
I'm trying a displacement, but it does not displace.
Suggestions?
Windows 10: Cinema 4D R19 + Octane 3 plugin
http://www.renderingart.it
It's normal message when you open a scene which is used older version of plugin. It makes some revisions for compatibility.
My suggestion is that post somethings to give more idea what you do.
jelly
Thank you, it was an old scene, saved and re opened a new one and in works ok. I probably was making some mistake, it's fine now.
