Getting the path to a texture image file from material nodes
Forums: Getting the path to a texture image file from material nodes
Postby MB » Mon May 23, 2016 6:44 pm
MB Mon May 23, 2016 6:44 pm
All,
I have been unable to figure out how to get the paths to any texture image files used within a material.
I would like to get all image files a material might use, i.e. normal and bump maps as well as diffuse and specular. Could anyone enlighten me.
Many thanks
Mark
Windows 7 Enterprise, 2x Intel Xeon X5650 2.66 GHz, 24GB Ram, GTX 590, Quadro 5000, Quadro K4200
MB
Re: Getting the path to a texture image file from material nodes
Postby roeland » Mon May 30, 2016 2:27 am
roeland Mon May 30, 2016 2:27 am
You can recursively walk over all the input nodes of the given node:
local function walk(node, list)
    -- recursive walk
    for i = 1,node:getPinCount() do
        local src = node:getInputNodeIx(i)
        if src ~= nil then walk(src, list) end
    end
    -- see if this node has a filename attribute
    local ok, value = pcall(node.getAttribute, node, "filename")
    if ok then
        table.insert(list, value)
    end
end
local list = {}
walk(octane.project.getSelection()[1], list)
for k, v in ipairs(list) do
    print(v)
end
To check if any node has a file name attribute, you can use pcall, a standard Lua function which calls another function (octane.node.getAttribute in our case) with the given arguments and catches any errors raised.
This code gives you the file names of any kind of file referenced by the nodes, not just image textures.
Roeland
roeland
Postby MB » Wed Jun 01, 2016 9:51 pm
MB Wed Jun 01, 2016 9:51 pm
Many Thanks Roeland
MB
Return to Lua Scripting
Thu Jan 21, 2021 6:17 am [ UTC ]
