Version 3.00 - R1.1 (25.05.2016)
jayroth wrote:Where is the TFD Flamethrower example file? It is not included in the TFD Examples download...
Added.
jayroth
Added.
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
jayroth
Sadly, I am not seeing any of the black smoke as seen in the photograph -- I am seeing flame only. I am using Octane 3 Beta 2.1, with Cinema version 17.046 on the configuration listed in my signature. Any ideas?
jayroth wrote:Sadly, I am not seeing any of the black smoke as seen in the photograph -- I am seeing flame only. I am using Octane 3 Beta 2.1, with Cinema version 17.046 on the configuration listed in my signature. Any ideas?
Be sure that you have density channel simulated and absorption/scattering is set properly. it doesn't appear without using object tag with proper settings.
kacperspala
There is no "scale" in medium node ? Just density ? Does it work the same way ? Cant reproduce some materials now .
ryzer 2700x
rtx 2080Ti
kacperspala wrote:There is no "scale" in medium node ? Just density ? Does it work the same way ? Cant reproduce some materials now .
scale -> density. It's same and renamed as standalone has been like that since some version.
Which material you can't do? It should work as old named scale parameter.
eyeonestudio
Octane 3.0 is glad to be released soon.
Most people will use Houdini to create openVDB.
Houdini 1unit is 1Meter.
C4D Default Unit is Centimeter.
VDB loader default scale is Meters. But Not Match Scale Houdini VDB. Hectometers is Matched Scale.
Particle Rendering - Dropdown Menu
I want to be a little change .
1.None
2.Sphere
3.Object Instances
4.Voxel
Thanks..... :D
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
Yambo
eyeonestudio wrote:Octane 3.0 is glad to be released soon.
1.None
2.Sphere
3.Object Instances
4.Voxel
Thanks..... :D
+1 for that
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
eyeonestudio
OpenVDB Velocity Motion Blur Testing
eyeonestudio wrote:OpenVDB Velocity Motion Blur Testing
all good?
Return to “Releases”
