Hey Tutor,
Most of our contributions here pale in comparison to what you add in these forums... It would be great if Smicha could transfer from one rabbit hole to the other without coming to the surface at all. But any shortcut strategy involves more risk of course.
Keen to hear the results. I think that once it works though the words 'do not touch' should be laser cut into each side panel...
Seeker
Best Practices For Building A Multiple GPU System
- Seekerfinder
Guys,
You are all awesome. I really appreciate your willingness to help. If I had the machine it would take me no more than 2 hours to drain the loop, remove them all, reset bios, at test them one by one and do all the stuff, including asus flashback which I've done dozens of times. Believe me -removing the water of the loop takes 5 minutes, removing the 7-way bridge takes no more than 10-15 minutes. So (for me) it's pretty quick and easy. The problem is that I have to assist the guy remotely and first test all other possibilities.
Tomorrow morning we're testing putting back power cables. If this is not good we'll go with the drainage. I'll report you on all.
- Seekerfinder
Oh... I missed this part. Bummer. It's obviously not great for the end user but I hope your client at least appreciates that that system is an unusual power house and that some snags are likely.smicha wrote:The problem is that I have to assist the guy remotely and first test all other possibilities.
Seeker
- Tutor
- Location: Suburb of Birmingham, AL - Home of the Birmingham Civil Rights Institute
Does wood conduct electricity? Yes, but it depends on moisture content [ https://www.quora.com/Does-wood-conduct-electricity ]. Teflon is even less conductive. So a teflon coated stand might be better than a wooden crate to raise a bunch of GPUs - just make sure the teflon coating covers all areas that might come into contact with GPUs and check the coating's rated temperature resistance and compare that to the environmental temperatures of the other heat contributors in the area of concern. You don't want any teflon or other insulator melting to occur.
conductivity of copper: 59,600,000 S/m
conductivity of graphite: 300 to 50,000 S/m
conductivity of wet wood: 0.001
conductivity of dry wood: 0.000000000000001 S/m
Conductivity of teflon: 0.000000000000000000000001 S/m
See also, http://www.lehigh.edu/~amb4/wbi/kwardlo ... tivity.htm .
Because I have 180+ GPU processers in 16 tweaked/multiOS systems - Character limit prevents detailed stats.
I am preparing something more scientific - if you guys could help with some data it would be great
viewtopic.php?f=11&t=53959
Anyone imagine what 8x Pascal GTX 1080 would score on Bench?
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Plugs: Enterprise
if OctaneBench numbers (after optimisations) will corelate to SP performance we are looking at 1200 out of the box & close to 1500 watercooled/Oced =) hitting 1000 would happen with 5-6 cards.Notiusweb wrote:Anyone imagine what 8x Pascal GTX 1080 would score on Bench?
I'm gonna say Titan X : GTX 1080 = 1:1.25 (my ball park is based off of some articles comparing FPS)glimpse wrote:if OctaneBench numbers (after optimisations) will corelate to SP performance we are looking at 1200 out of the box & close to 1500 watercooled/Oced =) hitting 1000 would happen with 5-6 cards.Notiusweb wrote:Anyone imagine what 8x Pascal GTX 1080 would score on Bench?
So, if 8 X scored 1,096 on bench, then 1,096 * 1.25 = 1,370.
So, I'm going to say for GTX 1080, 8 cards will hit 1,370.
Note that this is V2. It will be interesting to see if V3 actually scores higher/lower with same scenes in a bench run...
Plugs: Enterprise
Plugs: Enterprise
Tutor, what say you? (assume PSU and power is not a concern or limitation, and assume I have most optimal BIOS for adding GPU):
I am trying to max cards on rig from 13 to 14, but under my current arrangement I always get a d4 Out of PCI Resource error. Fine, okay...but in this arrangement my Titan X is connected to slot 1 at 16x.
Could halving my 16x connection of my Titan X to 8x alone allow me to add another card?
Or, would IO space say, "No, irrespective of how many lanes are used, I can only delegate so much address memory to so many devices. It's a device count thing, not a lane usage thing...
If you have 13 at 1x, 13 at 4x, 13 at 8x, or 13 at 16x...I don't give a F&$%...you're only getting 13...because that's all I can allocate address memory to...so F&$% off with the 14, you damn F&$%ing piece of S&*$..."
Plugs: Enterprise
Plugs: Enterprise
