ICE
face
Rendermap in Action ;)
[vimeo]http://www.vimeo.com/13538683[/vimeo]
http://vimeo.com/user2509578
Chris_TC
How does Octane receive the texture considering it's not static?
face
The plugin shows if a rendermap with name OctanMap in the exported mesh is present.
If a rendermap is present, the plugin will first render the rendermap, then export the mesh.
When the texture from the rendermap becomes ever the same name, Octane load ever the last rendered ;)
With that you can combine many textures in one...
face
kubo
all your test are really cool, and funky, but this last one is plain amazing. Keep it up!
p3taoctane
Gidday Face
I am the one trying to get his 2 teslas working in tandom ( I know everyone should be so lucky as to have that kind of problem. I am grateful to be able to try and fix it.) If you want to try any tests on my system... let me know. I am not sure how to send you a message offline. But if that idea sounds intriguing please let me know.
Otherwise keep up the amazing work. By far the most "wow" factor on the forum
Peter
face
Thanks ;)
The next one will be much better...
@p3taoctane
I don´t know how you can help me, but thanks :)
face
p3taoctane
will look forward to it.
Any other ideas onhow to get these cards to work together?
Peter
face
Ups, i think i have missunderstand you ;)
Maybe you can use the commandpromt and start Octane with that.
The syntax for the GPU´s is -g 0 -g 1 -g 2...
"-g 0 -g 1" select device 0&1
"-g 0 -g 1 -g 2" select device 0, 1, 2
To test, you can use the commandline
-n "xxxxx" = new project and the filename
-m "xxxx" = meshname in Octane
-l "xxxxx" = Link the meshname with this file
Octane.exe -n "G:\Octane\Project\test.ocs" -m test.obj -l "G:\Octane\Project\test.obj" -g 0 -g 1 -g 2
face
p3taoctane
I will try that and Radiance suggested using path tracing a and a bigger scene I shall do both
Peter
face
First test from the next anim ;)
face
Return to “Works In Progress”
