I want to use a JPG sequence as a texture map. It works find if I hit the "Rebuild scene" button in the octane render window. If not pressed, it does not work. Is there a button to activate such as "Always rebuild scene before rendering?" Or is there a work around?
Thanks in advance!
Best wishes,
Thomas
JPG sequence as texture map
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
I cannot reproduce this issue. What version of the plugin are you using? (The version numbers are in the Octane About box.) Can you post (or PM me) a sample scene that demonstrates this issue?
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Nevermind, I solved the problem... Thank you
I used AE and mocha
Best wishes,
Thomas
I used AE and mocha
Best wishes,
Thomas
