OctaneRender™ 3.0 for LightWave™ - Alpha build 3.00.10.0
BorisGoreta
I have 10 GPUs on 16x to 1x PCI powered attachments like this:
and they all work perfectly.
These kind of attachments were very dodgy in my experience:
such extensions worked properly only from one manufacturer, I had to ditch 10 such extensions from other manufacturers because they weren't working properly.
So my conclusion is simple is better !
Interesting clip about why GPUs fail internally:
https://www.youtube.com/watch?v=pRz_CG3DZb4
jang2235
In my case, the problem occurred.
I used a version 3.00.10.0 was an error to bring up the 60 million poly before rendering.
In previous versions, the problem appeared in a well-used system was quite surprised referred to the situation without any problems.
Connect directly to the motherboard and is not an error has occurred.
I used the cable of the second image
Combined with the system rather than a set speed, PCI-E only a matter of plug-ins are a problem that appears.
Lanes are going to need to replace the system with a lot of systems.
BorisGoreta wrote:I have 10 GPUs on 16x to 1x PCI powered attachments like this:
FrankPooleFloating
Juanjo.. Help! Alpha 10 is no longer working. :shock: It brings up license un/pw dialog and my login stuff is not working. Yes, I am using the ones from my license page and not the account un/pw... Need to get to work asap. Zoinks!
*I thought alpha/beta was supposed to work until 15th... then we need to buy 3.0... right?
Edit: Of course, this is f*cking Friday the 13th! I am an otherwise completely non-superstitious dude, but holy crap, I have had some bad F13s... too many.
BorisGoreta
go to user->Boris->AppData->Roaming->OctaneRender and delete otoy_credentials file
after relaunch you will need to reenter login data
FrankPooleFloating
Oh, thanx Boris!
FrankPooleFloating
Hmmm.. I see:
data (no extension)
license (no extension)
octane_render_v1_live_account.cfg
preferences_v2 (no extension)
one of those folders that has a string of letters/numbers in curly brackets (with data and preferences_v2 files in it)
localDb folder (empty)
:? I see no otoy_credentials file
BorisGoreta
Strange, then it is not the same problem I had, I got an authentication error window but it didn't ask me to enter my credentials.
share the screen
FrankPooleFloating
Alpha 10 in LW worked fine yesterday. I have done nothing and certainly not changed anything...
BorisGoreta
So you enter your credentials but they are not working ?
Send email to support@otoy something, they will answer promptly.
FrankPooleFloating
I just downloaded and fired up Standalone Beta 2, and got the same damn thing. OctaneRender Activation and my license un/pw are not working. :cry:
Guess I'll try emailing Otoy, but it is Saturday morning there now....
Return to “Lightwave 3D”
