3.0.12.72
- Compiled with Octane 3 beta 1 (3.0.12)
- Fixed issue where render statistics were not being displayed when render region was enabled
OctaneRender® for Poser (Windows/OSX) 3.03.3 [OBSOLETE]
Entire system crashed when resizing the window to change the resolution larger than the screen allows. Is there any way to change the resolution to something in the range of 3000 x 3000?
Version 3 of Poser 3.3.4.77/ Daz 3.3.4.25/ 3DS Max 3.03.4 - 4.20 octane plugins
X79 Sabertooth - i7-3930K 48GB RAM
MSI 1070 8GB Liquid Cooled
Windows 10 Pro x64 (ver. 1607)
If you click on the render resolution button (monitor icon), you can set the resolution to any size you wantwlebrun wrote:Entire system crashed when resizing the window to change the resolution larger than the screen allows. Is there any way to change the resolution to something in the range of 3000 x 3000?
So far this has worked fine for me up to very high resolutions
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
wimvdb wrote:If you click on the render resolution button (monitor icon), you can set the resolution to any size you wantwlebrun wrote:Entire system crashed when resizing the window to change the resolution larger than the screen allows. Is there any way to change the resolution to something in the range of 3000 x 3000?
Thank you for the information. I appreciate it.
- Redprophet
FYI.
version 3 beta: Nvidia drivers 361 and 365 crash Poser 10 as soon as I hit the open viewport button for octane. I installed the cuda toolkit which installed 358 I believe and all is well.
Version 2.25 does not crash with those drivers.
Those Nvidia drivers are working OK for me. Could you pls give me some detailed info above your system and I will investigate further. In particular, RAM, Windows Version, graphics card(s), are you using a separate card as the display adapter, is it all scenes which crash the nvidia driver, or just some, who Poser 10 settings are you using?version 3 beta: Nvidia drivers 361 and 365 crash Poser 10 as soon as I hit the open viewport button for octane. I installed the cuda toolkit which installed 358 I believe and all is well.
- Redprophet
Well. I reinstalled the 365.19 drivers and the crashing comes back.
Windows 10
Poser game dev. (10.0.5.28925)
i7-5820
16Gigs ddr4
nvidia 770 4gb
old amd 6670 second monitor
Windows 10
i7-5820
16Gigs ddr4
nvidia 770 4gb
- octaneplugin.log
- (173.58 KiB) Downloaded 253 times
- vstudiot.txt
- I have VS 2015 community installed and hit the debug if this helps.
- (22.62 KiB) Downloaded 310 times
Does it crash on the default Poser Andy scene? What does the Octane Log show after the Nvidia driver crash?Well. I reinstalled the 365.19 drivers and the crashing comes back.
Windows 10
i7-5820
16Gigs ddr4
nvidia 770 4gb
- Redprophet
It happens every time. Nothing has to be in the scene.
here is a gif.
man it is late.... have a good night.
here is a gif.
- octaneplugin.log
- (214.88 KiB) Downloaded 260 times
Thanks. I'm running Nvidia driver 365.19, and have not had a driver crash - and we have very similar hardware. Have you overclocked your card? Try underclocking as per the link in my signature. Also try removing the other card - just to make sure it's not causing the problem.It happens every time. Nothing has to be in the scene.
