Octane for Softimage 1.04 RC1 [Obsolete]
face
Post
This is the first release with Particle support.
For now, only internal particle types are supported. Instance shapes will follow soon.
The particle color is unsupported, because Octane can´t use it. It will first work after the OSL (Octane Shader Language) is released.
face
ADDED:
  • PointCloud support for internal particle shapes.
  • Option to disable pointCloud checking.
  • Option to set set particle size for shape type point/seqment.
FIXED:
  • Gamma value from the imager in the render/preview image isn´t used.
  • Artifacts in saved images (red, green or blue points).
  • Transformation shaders aren´t checked.
  • Images are saved although the renderer is aborted.
  • Meshes which becomes a new material, aren´t updated.
FUTURE CHANGES:
  • PointClouds instance Shape support.
DOWNLOADS
MANUAL
INSTALLATION INSTRUCTIONS
  • Please follow the installation instructions in the on-line manual.
NVIDIA DRIVER REQUIREMENTS
  • This version requires video driver 337.xx or higher.
http://vimeo.com/user2509578
face
Post
Have seen the version and the whats new text file isn´t updated.
Not realy a big problem, will change it with the next release.
face
User avatar (Default)
wireframex
Post
face wrote:Have seen the version and the whats new text file isn´t updated.
face
don't worry :)
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
face
Post
Only as an info, have build a Demo version, which i must upload tomorrow.
face
face
Post
Working on the stability. When it´s done, i will update the commercial and release a demo version.
So it take a little time.
face
Return to “Autodesk Softimage XSI”
