OctaneRender for Modo 3.03.3 [STABLE]
MrFurious
face_off wrote:
Many thanks, looking forward to the next release.
It's in the version I posted yesterday. There is not an exact match with Modo on your test scene, because you had the sphere position changing instantly - but it's closer....
Thanks Paul. I just loaded a scene im working on now to check and a couple things immediately cropped up. When I go to render , I get this message:
And this one:
Neither showed up before when I was using this version of the plugin "OctaneRender_for_Modo901_2_25_0_99_64bit" and I'm having trouble making them both disappear.
Also there is a noticeable difference in the rendered image between these 2 versions of the plugin "OctaneRender_for_Modo901_2_25_0_99_64bit" and "OctaneRender_for_Modo901_3_0_10_104_64bit" that look to be more than just a simple gamma adjustment even the reflections look a bit different.
Dino.
Dino Inglese
CG Artist
Melbourne Australia
Intel Core i7-4820K, 3x GTX 980ti
Windows 7 64bit, Modo 12.2v2 for PC
Octane build 4.04.0.145
Hi Dino - that message means you have connected a modo schematic node to an Octane node like a material, emission, etc. If you are connecting modo nodes to Octane nodes - it needs to go via an Octane Float, Int or Bool node. I will put together a quick video explaining how this is done.
And this one:
That message means there were multiple UV vertex maps for the background mesh and the plugin couldn't match them with the other meshes. The video at https://docs.otoy.com/#42Using%20Multiple%20UV%20Maps explains how to address this.
I suspect that is a difference between Octane 2 and 3. You may need to adjust the gamma, or kernel settings to get an exact match.
MrFurious
Thanks heaps Paul your video was helpful and I've sorted out the UV error. With the schematic issue, I have a ton of node chains in my scene, is there a way to pinpoint the offending ones?
Cheers,
Dino.
Dino Inglese
CG Artist
Melbourne Australia
I will have the pop detail which actual nodes/materials at causing the problem in the next release.
MrFurious
Awesome that would be a huge timesaver.
Dino Inglese
CG Artist
Melbourne Australia
MrFurious
It's a pretty close match for regular object motion blur. (haven't tested sub-frame MB yet though)
I found an oddity though, could you please check my sample scene. On frame 4 (last frame) modo displays motion blur but octane does not. But if you go to the octane kernel options-->animation-->shutter alignment I noticed the setting is on 'symmetric' by default. If I use the drop down menu and select 'symmetric' again, octane displays the correct MB, but I have to manually select symmetric every time I open the scene.
Cheers,
dino.
motion blur test.rar
(10.82 KiB) Downloaded 173 times
Dino Inglese
CG Artist
Melbourne Australia
I will fix this in the next release.
Following is a pre-release of the Octane 3.0 Beta1 build of the plugin. Because of the large number of changes, I am posting this as a pre-release, and if no serious issues are found I will post it as a full release with OSX and Linux installers.
3.0.11.105
- Compiled with Octane 3 beta 1 (3.0.11).
- Fixed issue where render statistics were not being displayed when render region was enabled
- Added Baking Camera UV Region Minimum and Size
- Removed Render Passes Filter Size (deprecated in Octane 3)
- Added Mesh->Octane-Color which sets the color used for rendering the ovject when the Object Layer Color pass
- Stereo Eye Distance now has a range -1 to 1 to match Octane Standalone
- Removed Volume step length from the Kernels to match Octane Standalone
- Added Disable Partial Alpha and Gamma Before Response to the Imager settings
- Added Invert Absorption pins to the Scattering and Absorption medium nodes
- Resolved issue where the samples per pixel was not being reported when Render Region was active
- Set a maximum of 128 texturemaps that can be entered into the octane.createUdim command
- Fixed issue where Shutter Alignment was not being correctly set in Octane
https://render.otoy.com/customerdownloa ... _64bit.exe
Another tutorial...
MrFurious
Thanks Paul great video. Is octane for modo any closer to being able to copy/paste objects between scenes with octane overrides intact?
Dino Inglese
CG Artist
Melbourne Australia
Return to “Foundry Modo”
