Image not showing
Hi Erik,
so to recap, you are using Rhino for modelling and Octane Standalone for rendering, correct?
Could you share any simple obj object that give you issues?
ciao beppe
erikj7
Hi Beppe,
Yes, Rhino for modeling and/or converting the file(s) from .STL. and Octane as the Stand Alone.
I can open downloaded scenes in Octane and they display everything that is intended. However, when I bring my own .OBJ into the program by right clicking in the Graph Editor area I roll over Geometry and select Mesh, but it will not display the .OBJ. It does not matter which .OBJ I select, whether it's my own converted from .STL to .OBJ, or if I load a model purchased from Video Copilot for their Element 3D plugin for After Effects. I even created a simple sphere in Rhino, exporting it out as a >OBJ, and received the File Load Error message.
I've attached .OBJ regardless.
I really hope it's me doing something wrong, and something I've overlooked.
Thanks for your continued help regarding this.
-Erik
shoe_body.obj
(5.28 MiB) Downloaded 208 times
Hi Erik,
Octane works in meter, so , if your mesh has a different scale, you have to change the setting in the mesh preference pane. Here is what I get with the scale set to millimeter:
and here is the scene with your obj:
shoes_comp.orbx.zip
(1.77 MiB) Downloaded 194 times
happy rendering :)
ciao beppe
erikj7
Thank you Beppe! It worked.
Now I have another question, but will have to start another post about 'how to export a .mtl file, or something like it to accompany my .objs, so I can bring them into AfterEffects plugin Element 3D and make video footage'.
Thanks for your help.
Regards,
Erik
