Hello, I have a problem with rendering in PV, however in octane live preview scene works fine.
Here log:
FRAME 80 fps:24 camMb:0 objMb:0
Tried to access null item
FILE is not found:
FILE is not found:
FILE is not found:
FILE is not found:
FILE is not found:
Export materials time= 906.123 ms
Collect objects time= 7.311 ms
Mesh creation time = 13317.324 ms.
Triangle count:12.554m
CUDA error 1 on device 0: One or more of the parameters passed were not within an acceptable range of values.
-> failed to bind texture to device memory (data5)
device 0: failed to bind data texture 4 of context 0
<<< Render Failure >>>
Total export Time = 93007.615 ms
movable:0 Nodes:235 camMb:0 objMb:0
Rendering black in Picture Viewer
Hi ReaperTheOne,
please, could you specify which plugin version, c4d version and hw used?
If you cannot share it, other info/screenshots about the particular scene are more than welcome, like the schene structure, nurbs objects, other plugins used ecc.
ciao beppe
ciao beppe
- ReaperTheOne
Hi
thanks for sharing more info and screenshots, even if the only thing that comes to my eyes is that the Screen.1 object doesn't have octane materials while all the other objects seems to have a correct material.
Anyway, I don't know exactly at what resolution you are working, but could you try with v3 alpha 10?
viewtopic.php?f=85&t=51856
In v3 the frame buffer is no more loaded in VRAM, so there are less differences between what you have in LV compared with PV.
ciao beppe
ciao beppe
Why do you have 12millions triangle for a simple scene? Do you have subdivisions?
Also we can't see render info lines in you LV, don't you use it for checking the scene?
- ReaperTheOne
Nope, v3 does not helping. Here's the scene file, hope that will help to find the issue.
- ReaperTheOne
Yes, there is subdivisions, actually it's pretty high detailed models.aoktar wrote:Why do you have 12millions triangle for a simple scene? Do you have subdivisions?
I do, it was hidden for some reason, sorry. It actually export scene in LV pretty fast, but in PV it's about 1:30 min before it gives me the black screen and render failure.aoktar wrote:Also we can't see render info lines in you LV, don't you use it for checking the scene?
What's your gpu and VRAM?
I think it's not enough for 24millions polyon on Picture Viewer. Also check subdivision difference for editor vs. renderer. LV uses editor settings. Try for testing in LV with editor subdiv=3. I suppose that will give Cuda error.
- ReaperTheOne
It's GTX 980 and 32 gb DDR4, which needed for more then 24 milllions?aoktar wrote:What's your gpu and VRAM?
And thank you! Set the render subdivisions same as editor, now it works fine!
This is gpu renderer so primary factor is gpu's VRAM not system RAM. I see it's 4GB. But V2 has a triangle limit around 19millions. This has been removed with V3-Alpha but still limited by available gpu VRAM.ReaperTheOne wrote:It's GTX 980 and 32 gb DDR4, which needed for more then 24 milllions?aoktar wrote:What's your gpu and VRAM?
Btw plugin also requires some RAM for export process and depends to how you structured and which render settings are used.
