v3.0a10 - 3.2 [ALPHA] crash 2015 and tbb.dll
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
justix
Sadly the alpha does crash my max 2015 and on unistallation to put the latest 2xx takes the tbb.dll out of the system, I had to replace it with one taken from internet but now the hidden view is corrupt.. nice one :o
anyone else?
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
ThaRaven
Reinstall the Alpha. Had the same issue.. i had octane 3 as standart renderer. once uninstalled i get the tbb error and could not start max.. reinstall Octane Alpha 3 and set the scanline renderer as standart then quit and uninstall octane.. error should be gone. worked for me
Win 7 64 | Geforce GTX780 |Dual X5667 Xeon | 40GB | MAX 2016 |
justix
ThaRaven wrote:Reinstall the Alpha. Had the same issue.. i had octane 3 as standart renderer. once uninstalled i get the tbb error and could not start max.. reinstall Octane Alpha 3 and set the scanline renderer as standart then quit and uninstall octane.. error should be gone. worked for me
Thanks Iìll give it a go
justix
Nope, Sadly it does not work, I re-installed the Alpha, set the default to Scanline, then quit and unisntall the Alpha but still take the tbb.dll out ( but this time I made a copy of the dll ) 3dsmax still hang on opening of the materials slot. :?: p.s. and Max 2014 too
ThaRaven
the TBB.dll was introduced in octane v3 i presume. so if you uninstall it and had scanline as default and then installed octane v2 there should be no tbb error. thats what happened with me. Octane v2 does not install the tbb.. but octane v3 does. ps im on Max 2016 not sure if it makes a big difference
azen
Thank you for raising this issue. It seems that that uninstall process needs to be improved. I will run some tests on my end to get a better grip on the issue.
Thanks again for raising the issue.
Return to “Bug Reports”
