reload texture
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
WhyGee
I have many objects using a common material with a texture's reload flag enabled. It would seem to reload the texture for every instance of the geometry even though it's the same texture in the same material. Is this normal behavior?
The texture is quite large so the load time is significant for each geometry to reload.
Yaniv
juanjgon
Weird, if the objects share the same material, the material should be loaded only once, so the texture node should be evaluated only once (and therefore the texture reloaded only once).
Are you sure that Octane is reloading several times the same texture in the same texture node? If you can share a scene with this behavior I could test it here.
WhyGee
I will try to recreate something simple.
WhyGee
attached is a simple scene with 10 objects referencing the same material (at sop level, haven't checked if that is the reason or not). To make the attachment small I've removed the texture but simply plug something high res, i've tested with a 150mb HDR texture just so it will have some noticeable load time. when reload is enabled it stalls on each object for what appears to be the same load time. Without reload, only the first object is slow to load, and then the scene starts rendering quickly.
Yaniv
reload_texture1.rar
(24.72 KiB) Downloaded 269 times
juanjgon
Sorry, yes, you are right. The material is shared among all the objects (there is only one Octane image texture node for the whole scene), but it is evaluated for each OBJ node at loading time, so as you say if the reload texture option is enabled, the texture is reloaded for each OBJ.
I will try to fix this issue for the next build. Meanwhile I suppose that a workaround can be have two cloned materials, one with the reload texture option enabled and other with it disabled, and use the material with the option enabled only in one object. This should be enough to reload the texture map for all the objects, loading it only once.
Thanks for reporting this issue!
WhyGee
Great thanks alot!
Yaniv
WhyGee
I don't know if you've managed to get around to this issue by the latest release, it appears to still be happening in the last build.
juanjgon
Nope, sorry, not yet. I need to modify some things in the plugin architecture to make it possible, but I hope to have it ready as soon as possible.
Is the workaround using two materials working for you?
WhyGee
I can work with it, not urgent. Thanks!
Return to “Bug Reports”
