Thanks Tom, I appreciate your suggestion and the helpful guidance.glimpse wrote:Yeah, I was refering to this. A while ago one Guy on Fb group was in panic as He couldn't even start computer (minig rig like setup) with more GPUs it wasn't moving anywhere not booting at all (he was using splitter from Amfeltec). I was like ready to send my splitter (as I had working tested unit sitting unused), but then Amfeltec support suggested to ground things up & that solved problems. So I was thinkin' maybe that (missing ground somewhere) has anything to do with stability in Your case as well.Notiusweb wrote: Tom, were you referring to a physical ground wire here? That's interesting you ask that if that is what you meant, Amfeltec first asked me to attach a ground wire to the PSU, to the Amfeltec Chassis, and then to the PC chassis. I actually tried it 2x with a 10-guage ground wire, with no effect. When you find yourself doing unusual things to make something normal you start to feel like you have a problem with that arrangement.
In my own conversations with Amfeltec they had that among their leading steps of debugging.
