Consecutive Scenes rendering error
Moderator: BK
morphious2013
I have a 50 frame file. couple characters in the scene. Their positions change slightly in each frame. This is not an animation, but a work around to NO render cue for individually saved scenes. Octane renders do not match camera angles, and will render the same frame several times in a row, without rendering the slight position change of a character in the scene. V2.25. And no I didn't try V3 as I am not upgrading, so lets fix this in V2. Thanks. :)
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
morphious2013
Anyone got any ideas? Thanks.
I haven't had any other reports of this problem. Can you post a screenshot of the Animation tab from the plugin for the scene which is not working pls?
Also, try reproducing this problem with a couple of moving cubes. If the problem happens then, pls send me the .duf file from the 2 cube scene and I will take a look.
Regarding updating to Octane 3, at some point in the future, support for the Octane 2 version of the plugins will terminate (as support for Octane 1 ceased some time ago). So I highly recommend upgrading to Octane 3.
morphious2013
Attached are the files. Same results. Rendered frames do not match the animation.
Cube Test.zip
Files from Cube Test
(2.96 MiB) Downloaded 155 times
Tab from Characters Animation
I rendered on my system and the saved images match the DAZStudio viewport exactly.
What version of the plugin are you using?
Can you post a screenshot showing all of the Preferences tab of the plugin pls?
morphious2013
Version 25.0.16 Attached are the screen shots of Pref Tab. Oh Also. The thumbnails of the rendered images are not showing up in the window that pops up after animation is done. Just a black box with a small red X in the corner.
Your settings are identical to mine. The only difference is that I am rendering with the later Octane 3 version of the plugin (3.0.6.18). It would be worth you trying that version to see if it resolves your issue. That version should also resolve the thumbnail problem.
morphious2013
Ugh. Ok. I'll give it a try. How much U.S. dollars is the upgrade? And when available?
You dont have to upgrade now in order to try Octane 3.0. Your Octane 2.0 licenses gives you free access to Octane 3.0 alpha. For the upgrade price, you'll need to check the various threads in this forum.
Return to “DAZ Studio”
