Pb with instances
BorderLine
Hi JuanJo,
1 - I've problem with Lightwave instances. Doesn't appears when i render.
Last version Plugins
Thanks in advance
juanjgon
Hi! Are you sure that you have the object to be instanced enabled in the scene editor? The plugin can't instance the objects that are not enabled in the scene editor.
BorderLine
Doesn't touch anything and this morning, it's OK.
I don't know what's happen or what's i do.
juanjgon
OK. If you have this problem again, please let me know.
3dreamstudios
Yea I use instances constanly and don't have issues. But like mentioned the objects that are being instanced need to be enabled in scene editor. I know sometimes for different odd reasons I have to load up IPR again for things to show correctly. And the RELOAD button in IPR doesn't always do the trick. Can't say instances have been the issue but texture changes like smoothing, some odd light changes on occassion etc. But this may be unrelated.
Instances work great here...good luck!
Return to “Lightwave 3D”
