OctaneRender® for 3ds max® v3.0a9 - 3.0 [OBSOLETE]
Goldisart
garytyler wrote:
Goldisart wrote:textures are baked perfectly !!!! I like this option ...
to bake textures you need 1. set in the camera mode, Octane - mode baking ... 2. to prepare the right unwrap object . 3. To specify an ID and retrieve the scan baking with a variety of channels in the octane viewport 4 save 5 to assign to the object
......... I'm having difficulties with baking large scenes
May I ask what the difficulties are with large scenes?
handmade - no script - no support Automat unwrap max //// I hope they will make
DartFrog
I set all my objects to baking group ID 3
I set my camera mode to baking.
I set my camera's baking group ID to 3.
I have attached the render from a typical camera for reference, and the output file from baking. But the output file from baking doesn't really make any sense.
The baked file that was created
A reference for what the scene looks like.
Goldisart
I went down to 2.х ... I'm not experimenting in 3.х - can not verify your problem
JimStar
Goldisart wrote:I went down to 2.х
Yes, this is a right thing to do. This first alpha is for enthusiasts testing only. Do not even try to use it for work.
A couple of bugs reported here are Octane core bugs, a hard work on which is still going on... So, I'm not going to release a next plugin's alpha before Octane core alpha 10 is out with some fixes...
So far a work on plugin's fixes and improvements not bound to Octane core bugs is going on... So the more useful bug-reports here - the more will be fixed in next plugin's alpha version...
wastzzz
Tested, worked nicely, at some point 3dsmax was freezing everytime i created a new rgb image node. Dunno why.
So I rolled back to 2.21, but not much of a problem, all my scenes still render fine!
paoloverona
wastzzz wrote:Tested, worked nicely, at some point 3dsmax was freezing everytime i created a new rgb image node. Dunno why.
no problem at all?, bad UV mapping translation (from old scene) or with the texture emission map?
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
wastzzz
Well rarely I use the octane box mappings and texture emissions so I couldn't test it.
The problem I had was a severe system hangup after some point when creating materials, with 3dsmax freezing up and all.
Regards,
Max.
thanulee
Hi, the region render doesnt update when i change material properties. Max 2015 and 2016.
Actually it freezes and need to reopen kernel.
Also gamma and texture uvs do not work. Also the fog seems all over the place, i couldnt get a volume light but maybe it was my fault.
HHbomb
"pretty unstable release.... but already fantastic"
I'm happy guy : just fantastic :-) All is smooth for me except mapping nodes. ( i just play with alpha 9 and don't try net rendering )
Can't wait the new alpha ( alpha 10 is already out Jim ) with correction in all mapping problems.
I get same limitation as in version 2.x : can't render 2 millions cubes with pflow...
Maybe a standalone question but I don't know : could it be possible to use another camera then rendering one to map texture on mesh ? Is it possible to bake in another UVmap id ?
JimStar
Next version HERE.
Locked
Return to “Releases”
