RenderMan
JackMcRip
Feature list:
Full support for RenderMan RIB format for animation environments
Do you plan only a file format RIB ?
Or do you thinking about a renderman server like:
* Pixar's RenderMan Pro Server (Windows & Macintosh)
* dna research 3Delight (Windows & Macintosh)
* Sitex Graphics AIR (only Windows)
this applicantions can render in Cinema4D an some other 3D-Apps.
I must install a Render-Server on my machine and my 3D-App use the renderer to render inside the editor and the integrated render manager.
http://www.maxon.net/en/products/module ... neman.html
C4D + ZBrush User
Use AMD Phenom 9850, GeForce 8600 256MB, 8GB
radiance
We are working on a RenderMan Compliant RIB file parser/loader,
but it will not be a full implementation, due to GPU constraints.
We will make a release with the basics first, then add more and more.
We also won't implement a lot of stuff in the rispec that's old, like spot lights etc...
Radiance
Lutze
Looking forward to the RIB-support. I use Houdini, and since Houdini exports in RIB format it will be much easier to get the data to Octane. At the moment it is very time consuming to first get the data from Houdini to Blender or XSI and then to Octane.
Lutze
_________________
System: AMD X4, 2x GTX470, 8GB Ram, Win7-64Bit
n1k
Can anyone please write something about how RIB works? I never used it before and just want to know how it handles animation between host app and renderer. Tnx in advance:)
Cheers,
n1k
[email protected], 8gb RAM, Gainward GF 460 GTX 2048mb,Win7 64bit.
http://continuum3d.blogspot.com/
[gk]
Amiga 1000 with 2mb memory card
havensole
In a normal renderman render client it does handle the animation data. Eventually octane might carry this data as well. It all depends on how they are able to process the animation data. If it does work properly it should eliminate the animation process incorporated now. No more frame by frame exporting and such. One would think.
System 1: EVGA gtx470 1280Mb and MSI gtx470 1280 in Cubix Xpander for Octane, AMD 945, 4Gb Ram
All systems are at stock speeds and settings.
