Octane for Softimage 1.03 RC3 [Obsolete]
face
Here is the second release with some changes.
For the material save, you can see a video on Vimeo:
http://www.vimeo.com/163360996
Hope you will like the changes,
face
ADDED:
  • Materials can now be saved and open in Octane standalone.
  • Option to disable mesh checking.
  • Option to disable material checking.
FIXED:
  • Memory leak with instances.
FIXED:
  • The Version Check is changed a little bit.
FUTURE CHANGES:
  • PointClouds will included.
DOWNLOADS
MANUAL
INSTALLATION INSTRUCTIONS
  • Please follow the installation instructions in the on-line manual.
NVIDIA DRIVER REQUIREMENTS
  • This version requires video driver 337.xx or higher.
http://vimeo.com/user2509578
wireframex
Thanks Face :)
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
wireframex
Crash report :
- Open XSI with or without any object
- Select Octane Scene render settings
- Click on Debug / Octane Node Graph Window
- On Render target node right click and select Show in outliner --> Crash
Main Computer:
face
wireframex wrote:Crash report :
There isn´t an outliner, the nodetree is only to see connection between nodes. It´s a residue from the standalone implementation.
The outliner is in the standalone on the left side, a scene tree like the xsi explorer.
You can also delete nodes in the node graph, but Softimage doesn´t know that a node from the tree is deleted and try to do the same when you delete the object in Softimage.
The result is also a crash.
What you can do is to change connections between nodes.
It´s only to debug a scene, also to see if all connections are ok or if all nodes are created and no trash is present.
face
face
A quick sneak peek.
Export time is 3sec., update the renderer will take around 20sec. 10million spheres.
face
wireframex
Very interesting :)
Main Computer:
Elvissuperstar007
you create the history! this program can be revived, but it takes effort not only render octane and other companies
Buckaroo
where is motion blur pass settings?
wireframex
Buckaroo wrote:where is motion blur pass settings?
Hi Buckaroo
Face told us --> Motion blur will no longer supported (1.03 RC1) viewtopic.php?f=29&t=53488
Phil
Main Computer:
face
I have removed it because it doesn´t work correct with pathtracing and the routine to calculate it, is a little bit wired.
After ICE i will switch to the 2.0/3.0 if available, which will have MB included.
face
Return to “Autodesk Softimage XSI”
