I'm just curious...
http://www.daz3d.com/simtenero-particle ... ete-bundle
Does SimTenero's Particle Physics work with Octane?
Moderator: BK
- linvanchene
In OctaneRender™ Standalone 3.00 alpha 7 there was some support for particles added.
viewtopic.php?f=33&t=53461Introduced new sphere primitive, which can be used for particles. Support for motion blur and the ability to load/save from/to Alembic is still missing.
If it works with Iray and 3Delight probably it could be made to work with OctaneRender.
But that would probably mean that both plugin developers work together or at least exchange some information.
I cannot judge how much time and effort would be involved in this specific case.
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
I'm not sure its actual 'particles'... But it generates 3D objects when it runs its simulation which might clog up daz..
Intel i7-4790K, Asus Z97-A, Corsair 32GB DDR3 1866MHz CL9, 2XAsus STRIX GTX980 DirectCU II OC 4GB, 4XSamsung 840 EVO Raid 10, Win 7 x64 Pro.
I've tried it and the "plugin" render properly only a few frames, after that freezes and render the same frame again and again before finishing.
In other attempts at the "Viewport" Animation not appear particles but continues to advance the timeline. I had to create a new camera into the same site of the previous camera and the particles appear in the "Viewport" to generate the animation.
Intel Core i5-2500 CPU @ 3.30Ghz (Quad Core), 12.0GB RAM, NVIDIA GeForce GT 620. Windows 7 (64 bits)
This is a separate issue to the particles. Which version of the plugin are you using? What did the Octane message window show?I've tried it and the "plugin" render properly only a few frames, after that freezes and render the same frame again and again before finishing.
Which version of the plugin are you using?face_off wrote:This is a separate issue to the particles. Which version of the plugin are you using? What did the Octane message window show?I've tried it and the "plugin" render properly only a few frames, after that freezes and render the same frame again and again before finishing.
R3.0.6.18
That you can see in the first attached image. Above.
And 3Delight and Iray materials particle system, the plugin does not make.
Best regards.
The particle system still does not work, Face_off could you fix it in the future?
- Operating System (ie. Win XP, Vista, 7, 8)
Windows 10 (64 bits)
- Amount of RAM
16 GB
2 GTX TITAN X
- Nvidia driver version
382.05
- DAZ Studio version
64 BITS - 4.9.3.166
- OctaneRender for DAZ Studio version (ie. 2.24.2.1)
3.6.5.33
How can I change my signature below this text?
- Amount of RAM
16 GB
2 GTX TITAN X
382.05
64 BITS - 4.9.3.166
3.6.5.33
Hi - the "Could Not Save Frames for 11 times" message means the plugin could not save the png or exr file - and I don't think it has anything to do with the particle system. That could be because DAZStudio does not have write access to the folder the images are being saved to, or perhaps there are special characters in the foldername, or you have run out of disk space. You will need to try different filenames and foldernames to determine specifically why this is happening.
