Version 3.00 - Alpha10.1 (30.04.2016)
joecurrie
Hi Aoktar,
Thanks for the quick response, maybe that was a bad example scene. I have replicated the problem using a new scene with only a cube and octane daylight.
Same thing happens - Render to picture viewer fails unless I render in live viewer first. I've added screen grabs of the 3 steps I have to take to render to picture viewer.
Thanks for any help.
Started logging on 06.04.16 15:53:42
OctaneRender 3.00 alpha 6 (3000006)
no interface found with subnet address 192.168.1.0, not changing the daemon scan subnet
Scene created in plugin version -1
FRAME 0 fps:30 camMb:0 objMb:0
docFrame:0 edRender:0 curFrame:0 From:-1 To:1 rFps:30 docFps:30
Static cnt changed at Frame:-1 cnt:1
Static cnt changed at Frame:0 cnt:0
Total time:6.201 ms. Estimated time:4.134 ms.
Calculation completed.... frames:[-1-2]
Export materials time= 0.063 ms
Collect objects time= 0.022 ms
Mesh creation time = 2.295 ms.
device 0: can't bind to render thread (0x0) in scope of other thread (0x7fdce5047e60)
device 1: can't bind to render thread (0x0) in scope of other thread (0x7fdce52dc790)
Triangles:12 Disp.triangles:0 Hair count:0 Mesh count:1
<<< Render Failure >>>
VRAM used/free/max:0Kb/0Kb/0Kb
Total export Time = 253.527 ms
movable:0 Nodes:17 camMb:0 objMb:0
Export materials time= 0.031 ms
Collect objects time= 0.025 ms
Mesh creation time = 2.313 ms.
VRAM used/free/max:345Mb/2.021Gb/4Gb
Total export Time = 652.445 ms
Static cnt changed at Frame:-1 cnt:2
Total time:15.807 ms. Estimated time:10.538 ms.
Export materials time= 0.058 ms
Collect objects time= 0.024 ms
Mesh creation time = 2.051 ms.
VRAM used/free/max:348Mb/2.046Gb/4Gb
Total export Time = 108.518 ms
movable:1 Nodes:17 camMb:0 objMb:0
Step 3 - Render to picture viewer after scene is loaded into live viewer- Ok
Step 2 - Render to live viewer - Ok
Step 1 - Render to picture viewer - fails
Mac OS X 10.11.4 - Cinema 4D R17 | Geforce GTX980 + 980ti | 32GB
joecurrie,
Can you check the gpus are activated before render?
joecurrie
aoktar wrote:joecurrie,
How do I check they are activated? they are ticked on in the devices panel. Or is there another way to check if they are activated?
Another weird thing is as soon as I open C4D I get the same error pop up in the log even when I haven't pressed render on either the live viewer or picture viewer, does octane do a startup check or something when opening C4d? -
device 0: can't bind to render thread (0x0) in scope of other thread (0x7febed5a0b60)
device 1: can't bind to render thread (0x0) in scope of other thread (0x7febed5a2150)
I've been searching for articles related to the error - "device 0: can't bind to render thread (0x0) in scope of other thread" but can't find anything about it.
thanks for your help.
joecurrie wrote:Hi,
In settings->devices. They should be selected. Btw do you have network clients or selected network render in somewhere? Looks like first error about wrong subnet settings. Second seems like devices are not activated. But we have some controls to activate before rendering.
abstrax
Ok, there are two issues here:
This warning you get when an incorrect sub-net is configured in the network settings. To fix it, open the network settings dialog and disable network rendering. If you want to use network rendering, configure the correct sub-net and enable network rendering again.
This one is weird. It looks between a race condition between starting and stopping the render threads. When do you get these error messages? During startup of the plugin or when you start rendering? What is the device configuration in the plugin?
joecurrie
Hi thanks for the speedy help so far guys appreciate it!
Both GPUs are selected in settings->devices.
980 ti - On - Priority
980- On
I have tried both individually and get the same "can't bind to render thread (0x0) in scope of other thread "
I haven't set up or used any network render/clients before. I will try with internet off tomorrow, check the network render settings are off and report back. Could there be anything else I need to activate? It seems weird that it loads to the live viewer ok and then only renders in picture viewer whilst I have live viewer rendering/paused, is it something to do with loading into film buffer differently with live viewer? Maybe I should experiment with something in kernel settings?
It happens as soon as I start the plugin or render something, when rendering to live viewer this error pops up first but then starts rendering. When rendering to Picture viewer if the scene is not loaded into live viewer it gives this error and render failed.
joecurrie,
Can you make a test with same very simple box scene to reproduce error? Here is a text file "octane_log_flags.txt". It will produce some log output for us. Please put it to folder where is the Cinema4D executable. And try to generate same errors. Then find the generated "octane_log.txt" file and post here please. It can give more idea.
(65 Bytes) Downloaded 265 times
abstrax
joecurrie wrote:I haven't set up or used any network render/clients before. I will try with internet off tomorrow, check the network render settings are off and report back.
Network rendering doesn't have anything to do with Internet. It uses the local network only, which you need to configure in the net render settings. If you don't use it, just disable it.
dinf
haze wrote:
ryzej wrote:Lovely test Yambo,
I can't believe how fast volumes render, it's amazing.
I'm running into an issue though, I'm getting a position wobble in these new versions with Houdini VDB's, I thought this was fixed in previous versions?
Clip:
https://www.dropbox.com/s/0ob8ztb00t7d4 ... e.mov?dl=0
This is most likely due to a bug that has just been fixed in Octane - there was an issue when importing VDBs with origins very far from the origin. Bear with us while we make the next release ready.
Thanks haze!
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
bertritude
Hi, THANKS FOR IT.
Do I need to update standalone version up to 3 before try the c4d v3 plugin ?
thanks for your help !
Bertrand
Return to “Releases”
