Error 999
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
prehabitat
Hi Paul,
Apologies if this has been asked before, and apologies in advance for not being able to provide any certainty with regard to my NVidia driver version.
I have been getting this error:
The error occurred first while I was testing some materials in the simple sample project; I didn't even get to load any octane materials; the error occurred while loading the scene.
I then tried a blank scene (template: none) and loaded a floor & 3D Camera only...
The error occurs in both 2015 and 2016 Revit. I haven't tried any back versions of the plugin; but I did try Rhino and C4d which both work fine...
As mentioned above I'm not sure what Nvidia driver version (ie 358.##??) I'm using because I am running my displays from the iGPU; and it seems I cant access the Nvidia control panel while no NVidia gpu's are being used for the display?
I can give you the driver information accessible from Device Manager:
Driver Date: 16/12/2015
Driver Version: 10.18.13.6143
HW setup as per the below; but without the K600 at the moment...
Thanks in advance...
P.S. I have been rendering with Rhino and C4d for a while; so I may not have used Revit Octane on this workstation since I reconfigured and reinstalled it all...
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
10.18.13.6143 = 361.43. Pls see the link in my signature regarding the need to use 358.50.
prehabitat
Thanks Paul, I had hoped it would be something silly like that.
Sorry for not looking harder for the answer
Return to “Autodesk Revit”
