I'm pretty much constantly trying to get tools/actions/etc together to help processing images(and other things) quicker. I have a heap of time-saving Photoshop actions already; and add to them often; but always find myself hitting a barrier when trying to plan any algorithm where I want/need to refer to relative adjustments which arnt available natively in PS(rather than absolutes; which are easier generally).
I think I'm going to have to get into some coding/scripting to take it to the next level.
Below I have a code snipped I've 'found' which will solve my immediate problem and allow a soft entry into coding via an immediately useful example - namely; it offsets the image by half the px Width & Height of the image (useful once you have a square image that you want to make seamless).
example code snippet:
// Save the current preferences
var startRulerUnits = app.preferences.rulerUnits;
var startTypeUnits = app.preferences.typeUnits;
var startDisplayDialogs = app.displayDialogs;
// Set Photoshop to use pixels as the unit value/rulers and display no dialogs
app.preferences.rulerUnits = Units.PIXELS;
app.preferences.typeUnits = TypeUnits.PIXELS;
app.displayDialogs = DialogModes.NO;
var id164 = charIDToTypeID( "Ofst" );
var desc49 = new ActionDescriptor();
var id165 = charIDToTypeID( "Hrzn" );
// We want to offset by a percentage so take the document dimensions in pixels
// and multiply it by the floating point percentage value in order to give the offset
// scripting listener code the amount in pixels, since that's what it expects
desc49.putInteger( id165, app.activeDocument.width * .5 );
var id166 = charIDToTypeID( "Vrtc" );
desc49.putInteger( id166, app.activeDocument.height * .5);
var id167 = charIDToTypeID( "Fl" ); // This line is highlighted in debug mode after I've try to play the script.
var id168 = charIDToTypeID( "FlMd" );
var id169 = charIDToTypeID( "Wrp " );
desc49.putEnumerated( id167, id168, id169 );
executeAction( id164, desc49, DialogModes.NO );
preferences.rulerUnits = startRulerUnits;
preferences.typeUnits = startTypeUnits;
displayDialogs = startDisplayDialogs;
Does anyone know JavaScript (and its use within the Photoshop environment) enough to help with the above?
I am also interested how I can package and call up the script once it works; but that's prob a pretty basic fundamental I can research myself...
