Compound node crash
gristle
Anyone else getting an instant crash when copying/pasting compound nodes with the IPR open?
11.6 and Octane 2.2
juanjgon
I will test this problem ASAP. I think I've ever worked with node compounds and Octane.
gristle
Great, thanks! First time for me as well. I was hoping to clean up the node editor a bit by using compound nodes for base surfaces.
Gets pretty messy with base surfaces, graphics etc. It seemed to crash sometimes even with the IPR paused.
gamedesign
I am getting crashes when using the compound node too. Does anyone know if there has been a solution to this yet? Thanks
juanjgon
gamedesign wrote:I am getting crashes when using the compound node too. Does anyone know if there has been a solution to this yet? Thanks
Can you send to me a sample scene with this problem? I have problems to reproduce this crash here.
gamedesign
Hi there thanks for your reply.
I just built a scene to show it crashing and its not doing it now, so I'm thinking it was something else causing it. If I come across it again I will let you know. Thanks again :)
Return to “Lightwave 3D”
