OctaneRender® for 3ds max® v2.25 - 2.21 [OBSOLETE]
JimStar
Plugin's version number consists of two parts - version of Octane core integrated into this version of plugin, and the version of the plugin itself.
Changes of the 2.21 version
  • Implemented the image border marker in Octane viewport if alpha is enabled and no background present.
Previous versions changelog (since major 2.0 release):
Changes of the 2.20 version
- Checker background behind alpha in Octane viewport.
- Implemented the perspective correction hack. Now if "Perspective correction" is ON for Octane camera and camera's UP-vector divergence is less than 0.6 degree from vertical - camera placement will be changed to vertical during translation. So, in some cases you perhaps may notice an inconsistency in camera tilt between viewport and rendered image when "Perspective correction" in Octane camera is ON... If you are able to see 0.6 degree difference of course...
Changes of the 2.19 version
- Fixed another Octane viewport bug.
Changes of the 2.18 version
- Fixed a bug: crashed during image porting from Octane live viewport to 3ds Max or in final rendering if non-Octane camera was used.
Changes of the 2.17 version
- New 2.25 engine.
- Fixed material color refresh in 3ds Max viewport.
- Implemented workaround for Bitmap's alpha channel saving screwed up by 3ds Max in some cases.
- Improved interactive render responsiveness.
- A couple of minor fixes and improvements...
Changes of the 2.16 version
- Improved non-linear workflow gamma processing. Material editor should have correct colors if Max gamma is enabled.
Changes of the 2.15 version
- Implemented a workaround to make a motionblur working for WSM objects.
Changes of the 2.14 version
- A couple of fixes in VRay converter.
- Improved gamma processing, to allow a proper linear workflow. Don't set Octane's "tonemapped" checkboxes if you have 3ds Max gamma enabled.
Changes of the 2.13 version
- Fixed one more issue with Octane viewport motion blur autorefresh.
Changes of the 2.12 version
- Improved Octane viewport alpha channel behaviour. Now it respects "Keep environment" setting.
Changes of the 2.11 version
- Implemented the animation of background for Octane viewport.
- Made the changes to Octane API to improve the material DB dialog user experience for the plugins: the material DB dialog is now asynchronous (you can import a couple of materials in sequence), and retains its full UI state between openings.
- Added "Perspective correction" to camera settings.
- Fixed the motion-blur refresh behaviour in Octane viewport in some special cases.
Quick-fix release.. Changes of the 2.10 version
- Implemented multi-material support for Forest Pack geometry objects.
Changes of the 2.9 version
- New 2.24.2 engine.
- Fixed crash in some cases of using "pick" in Octane viewport.
- Fixed camera "target focusing" mode.
- Fixed "Lock camera" behavior in the case currently locked view was maximized.
- Fixed Forest Pack objects rendering issue where the material assigned to Forest Pack "Custom object" was used instead of one assigned to Forest Pack geometry.
- Octane viewport is now refreshed automatically if motion blur parameters change in render settings.
- Implemented the hack to clean up the GPU memory every time after rendering is finished.
Changes of the 2.8 version
- Fixed bug: Octane viewport closed after render settings dialog closed.
- Fixed and improved the lock-resolution functionality of Octane viewport.
- Improved Octane's nodes displaying in "shaded" and "realistic" viewport modes. Implemented the support of all other texture nodes in addition to image textures (including Mix Texture) in "shaded" and "realistic" modes.
Changes of the 2.7 version
- Fixed bug: crash when closing the scene during Octane live-session active.
- Fixed bug: live-session refresh stop after drag&drop of the material or texture.
- Fixed bug: render elements regression, rendered black in final render mode.
- Fixed bug: IFL support regression.
- Implemented the full support of IFL format, including comments and frames-count numbers for each file. Now you can use the full format like this:
        ; Anything after a semicolon is a comment, and is ignored.
        sand.jpg 20
        stone.tif 40
        boulder.tif 25
Changes of the 2.6 version
- Implemented the native 3ds Max BitmapTex support as the alternative input for Octane Image textures. You can use the Viewport Canvas now to draw "on the fly" on the Octane textures.
Changes of the 2.5 version
- Fixed the GPU setup dialog issues.
- Fixed the bug: current batch render view animation rendering did not stop completely after cancelling.
Changes of the 2.4 version
- Fixed the minor bug: the newly implemented textures previews did not refresh in material editor in some cases.
Changes of the 2.3 version
- Added "Export Octane material" button to Octane materials properties rollout in material editor. So, now you can export some specific material, even just some subtree of full material's setup.
- Added "Enable texture" parameter to Octane sun.
- Added "Enable displacement" parameter to Octane render settings.
- Implemented Octane textures previews in material editor. You need to refresh the previews cache in material editor to get existing "black squares" disappear.
- Implemented the support of 3ds Max orthographic views. Important thing to notice: Octane camera can be thought as some "physical thing" that always has the position. The ortho-views' "cameras" in 3ds Max are just like "infinite frustrums" and always return (0, 0, 0) as "camera" position. So, if such a "camera" (after becoming Octane ortho camera) appears to be right in the center of the scene (or even worse in the center of some object) - you might see some objects "clipped". To avoid this please use the new "Ortho view shift" parameter in Octane's general camera settings. This parameter shifts the ortho-view camera position (along the view direction) away from the Max's (0, 0, 0) position to the needed distance. You can set this parameter to always have Octane's ortho-view cameras positions outside of the whole scene. Don't set this value toooo big "just in case" - as this may cause precision errors.
- Implemented support of orthographic mode for Octane camera nodes. See new "Orthographic" checkbox in Octane camera rollout.
- Fixed Octane's native "Focal depth" parameter not working for Octane camera nodes.
Changes of the 2.2 version
- Minor fixes and improvements... No new features, working on making this branch stable...
Changes of the 2.1 version
- Fixed the bug: the assignment to the complex Octane node parameters from MaxScript did not work. Now you can use MaxScript constructions like [code]sceneMaterials.Some____Glossy_material.diffuse_tex = RGBSpectrum_Texture()
- Fixed the render-settings dialog spinners bug.
- Fixed the issue when some materials did not load from LiveDB.
- Made the Octane image textures' filepath buttons to have the standard assets menu.
Changes of the 2.0 version
- Implemented the MaxScript support for Octane render settings. Big refactoring has been made to achieve this (together with refactoring described in bullet #4), the Octane scene data format has been changed significantly enough to not be able to have the old scenes converted "on the fly". So the scenes made in previous Octane plugin versions will be incompatible with plugin versions starting from this major 2.0 version. Don't switch the current critical projects to this version.
- Any changes of Octane parameters from inside MaxScript are instantly reflected in UI of rendersettings dialog (if opened).
- Changed the "filename" parameter type of Octane nodes: now it has the same standard "filepath" type as the same parameters in other 3ds Max native nodes and can be easily accessed from MaxScript.
- Fully refactored the Octane nodes' parameter ID generation algorithm: the new algorithm allows to easily extend Octane nodes inside 3ds Max by additional plugin-specific parameters in future. Thanks to this change the next feature is already implemented:
- Added the camera mapping support to Octane image textures. See the new "Camera mapped" checkbox in Octane image textures properties.
- Octane GPU config now can be stored with scene and accessed from MaxScript.
- Minor fixes of Octane viewport.
- "Elements Active" checkbox in render-elements settings is now respected by Octane.
- Fixed one more Octane proxy preview scaling issue: in the case the scene unit scale was adopted from loaded file having proxies in it.
- Other fixes and improvements...
[/code]
DOWNLOAD
THIS MAJOR VERSION'S SCENE FORMAT IS NOT COMPATIBLE WITH PRE-2.0 PLUGIN VERSIONS! DON'T SWITCH THE CURRENT CRITICAL PROJECTS TO THIS AND LATER RELEASES!!!
Read the changelog of this 2.X branch and discussions in previous threads of 2.X versions.
You can use the materials export/import to/from LocalDB to transfer the materials between 1.X branch versions and current versions.
Or the 2-stage converter.
OctaneRender for 3ds Max 2.25 - 2.21
OctaneRender for 3ds Max 2.25 - 2.21 DEMO
For network slave and daemon please download standalone installer here:
viewtopic.php?f=24&t=52329
Please, if you decided to report a bug:
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English. These threads have got overfilled by Google-translator balderdash that is impossible to understand.
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
Goldisart
It seems to me very contrasting line starting to hurt my eyes and there is an effect that the picture is floating
Goldisart
http://www.youtube.com/watch?v=MiiPhAPu2SI
I can't do contrast projection - 20:45
(I feel defective in comparison with cinema 4D)
Elvissuperstar007
perspective correction does not work.
darkline
Goldisart wrote:http://www.youtube.com/watch?v=MiiPhAPu2SI
+1 If it can be done, please do it light projection mapping.
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
darkline
Poss bug or just missing feature but how can I apply a material to hair and fur strands within the hair and fur rollout? Octane viewport keeps refreshing if I apply a spectrum texture to a root or tip color.
The only way I can apply an octane material at the moment is to select the whole object and apply a single texture to all the fur. I'm trying to do grass so want some colour variation. This doesnt seem to be possible if you can't access the material controls/parameters within the modifier stack. None of the properties work such as hue variation, value variation etc.
paoloverona
darkline wrote:Poss bug or just missing feature but how can I apply a material to hair and fur strands within the hair and fur rollout? Octane viewport keeps refreshing if I apply a spectrum texture to a root or tip color.
Hi Darkline, I was in the same situation (no way, at the moment, to make it work).
You have only two choises for having variations in your grass or whaterver need it (both require to follow the steps described here
viewtopic.php?f=27&t=53186 )
- with hair and fur, set your grass as desired then, under the "tools" panel, select hair>mesh. To the generated geometry apply the "material by element" modifier and follow the other instructions described into the link.
- with custom objects or planes to scatter with some tools, after scattered, attach every geometry that needs variation, apply the "material by element" modifier and follow the instructions.
....that's all I can do ;)
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
Goldisart
inactive button
2016-03-28 15-36-31 Render Setup OctaneRender 2.25 - 2.21.png (8.95 KiB) Viewed 7934 times
Goldisart
Really want to get Phisical support standard camera \ thanks - to work with octane camera is difficult
darkline
Thank you for this, but in this instance I need the grass to be animated by wind, so cannot convert to mesh.
Thanks anyway, will be handy for other stuff as a temp workaround.
Locked
Return to “Releases”
