Plugin Crashing Got strange error message
Moderator: BK
morphious2013
You comment my answers are incomplete. Your answers are the same. Just a bunch of quick fix answers. Why not explain why lowering out of core to 4gb is better than 13gb. Checking the 4 boxes on preferences. Must be my card. Must be the prop. Displacement maps. Card not enough. Why not take the time to dig a little deeper into the issue. Must be an issue with octane and the
G3 models. Works fine with G2 models. Why not dig into that issue. Yea I know,no one else having same problem. Well I am. If out of core doesn't truly work then maybe there inlies the problem.
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
I'm sorry - but unless you give me clear, unambiguous information, it is very hard to help you.
linvanchene
Not much to add:
- If you are low on spare VRAM make sure not to activate any unneeded subdivision levels in the DAZ Studio parameters tab
-> try switching some models in the background from "High Resolution" to "Base Resolution"
- check the texture resolution sizes!!!
Victoria 4 & legacy figures often used lower resolution textures. With Genesis 2 and especially Genesis 3 texture resolutions have increased
If you are using HDR background images to render some of them may be 4K or even 8K and eat away a lot of VRAM as well.
-> use the Textures tab of OcDS to reduce texture sizes to half or even 1/8 if objects are in the background.
Side Note:
-> at the GPU Technology Conference 2016 April 4-7, new video card models may be introduced.
http://www.gputechconf.com/
At this point in time it might be interesting to wait with a potential purchase until more information is available.
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
morphious2013 - have been able to resolve these issue?
morphious2013
No. I have to use props with lower texture counts and lower poly counts when using G3M/G3F together. Seems Out-of-core doesn't help. Tried different settings.
Return to “DAZ Studio”
