"Animation Error
Could not save a frame for 11 times!"
http://imgbox.com/fUhFKUPh < Evidence.
Tremendous disappointment. I never can create an animation with Octane Render for DAZ Studio. I had faith that it would work.
- Procesessor: Intel® Core™ i7-3770 Processor (8M Cache, up to 3.90 GHz)
- Operating System (ie. Win XP, Vista, 7, 8): Windows 10 Pro (64 bits)
- Amount of RAM: 12 GB
- Graphics Card(s) - model (ie. GTX 580, 3GB): GeForce GTX TITAN X
- Nvidia driver version: v364.51
- DAZ Studio version: DAZ Studio Pro 4.9.1.30 Edition (64 bits)
- OctaneRender for DAZ Studio version (ie. 2.24.2.1): 3.0.6.16
What's wrong my computer or plugin?
Animation Error!!!!!!
Moderator: BK
I have encounter this error too, it's on the V3 version when I select jpg output and the V3 API cannot handle jpg.
But your picture show a png8 output. That's strange.
All my animation render are OK when selecting png8.
When starting render, go to the folder and check if the image is saved. Could be a folder rights restriction. Have you test to output to another folder ?
I7-3930K 64Go RAM Win8.1pro , main 3 titans + 780Ti
Xeon 2696V3 64Go RAM Win8.1/win10/win7, 2x 1080Ti + 3x 980Ti + 2x Titan Black
I already changed the path of the folder to "Documents" and keeps going the same. Also I do not think it's for restrictions on the folder, I enter as Administrator and no other account in Windows. If you look at the picture again 85 that there should not be there, I have no option JPG.itou31 wrote:Hi,
Intel Core i5-2500 CPU @ 3.30Ghz (Quad Core), 12.0GB RAM, NVIDIA GeForce GT 620. Windows 7 (64 bits)
What does the Octane Log (in the Messages window at the bottom of the System tab) say?
Can you provide a screenshot of the contents of C:\Users\USUARIO\OctaneRender\Images folder pls?
How much disk space do you have free on c:?
1. http://imgbox.com/nSFj75DCface_off wrote:What does the Octane Log (in the Messages window at the bottom of the System tab) say?
2. http://imgbox.com/yYGhiGkl
3. 100 GB available of 465 GB.
A client paid me this animation that I try to do, and if I can not finish I will have to return the money.
I think the problem is the plugin trying to save a frame that is already saved in the Images folder. I will need to do some more testing after the Easter break to confirm this, however if you try saving to an empty folder it will hopefully render correctly. You could also try increasing the Max Allowed Save Errors.
I did what you suggested and still going the same. > http://imgbox.com/o8ddz9fx <face_off wrote:I think the problem is the plugin trying to save a frame that is already saved in the Images folder. I will need to do some more testing after the Easter break to confirm this, however if you try saving to an empty folder it will hopefully render correctly. You could also try increasing the Max Allowed Save Errors.
Did it save the render for all frames?
The following debug build of the plugin adds a message in the Messages area at the bottom of the System tab if the render image fails to save. It will hopefully give us a clue as to why it's not saving. https://render.otoy.com/customerdownloa ... _Win64.exe
Thanks, I've installed (3_0_6_16a) and now the error no longer appears under the same conditions of the scene, the plugin have rendered and saved all the frames correctly. I hope to finish the animation without the error appears again.face_off wrote:The following debug build of the plugin adds a message in the Messages area at the bottom of the System tab if the render image fails to save. It will hopefully give us a clue as to why it's not saving. https://render.otoy.com/customerdownloa ... _Win64.exe
I like the way you are attentive, regards.
