Using G3M and G2F, render a little slow. Add hair, and I get the following error. See attached picture.
Nvidia 364.51, Octane Plugin 2.24.2.5
This just started happening. Everything was fine. Maybe the latest updates? Weird.
Plugin Crashing Got strange error message
Moderator: BK
- morphious2013
Could it have started happening since you updated the NVidia driver?
- morphious2013
I'll have to try and go back a couple versions. I think there were 2 just recently. Weird thing is, I can use Victoria 4, and 6 with male counterparts, props, room scene, etc, and renders fine. If I have (2) Genesis 3 Characters, hair, genitals, and a simple bed prop, it crashes and give me the same error I attached last message. I contacted DAZ, but, well, their tech support is shall we say "clueless" to put it mildly. I can't see how a GPU driver and the G3 characters could cause a problem, but then again, it's a computer. Any other insights would be greatly appreciated.
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
- morphious2013
Well, cant find older plugin on Nvidia website. Tried rendering just a living room scene by i13 . Cuda error 999. Attached is a pic.
- Capture.PNG (4.77 KiB) Viewed 4304 times
Plugin? Do you mean "drivers"? I don't know what you mean by this - if you go to http://www.nvidia.com/download/find.aspx it gives you all the old drivers.Well, cant find older plugin on Nvidia website. Tried rendering just a living room scene by i13 . Cuda error 999. Attached is a pic.
This won't be a DAZ issue. It will either be hardware, Nvidia drivers, or Octane.I contacted DAZ, but, well, their tech support is shall we say "clueless" to put it mildly.
Thinks to try:
1) Reboot - often this fixes cuda error 999 problems.
2) Make sure you have NOT overclocked your card.
3) Roll back to cuda driver 385.50
If you still have the problem, it could be a hardware issue, or a problem with Octane, in which case try the latest 2.25 version of the plugin.
- morphious2013
I'm guessing you mean 358.50?
- morphious2013
Where do I find 2.25 version?
Sorry - yes, I meant 358.50.
The test version of the 2.25 build is at https://render.otoy.com/customerdownloa ... _Win64.exe.
- morphious2013
Still getting the Render Engine Failure Error as I posted originally. Octane 2.5 and the NVidia driver 385.50. With just G3M & F and hair and Gens, sluggish to render. Soon as I add a room, or prop, even just a bed, I get the error. Any ideas?
Unfortunately it's sounding like a hardware issue. Do you have a separate card as your Windows display adapter? Is the Poser plugin giving similar errors?Still getting the Render Engine Failure Error as I posted originally. Octane 2.5 and the NVidia driver 385.50. With just G3M & F and hair and Gens, sluggish to render. Soon as I add a room, or prop, even just a bed, I get the error. Any ideas?
Have you tried reinstalling Octane Standalone (via the installer .exe) to set your Nvidia driver time-outs?
Try underclocking your card.
