OctaneRender for DAZ Studio 3.02 [OBSOLETE]
Moderator: BK
itou31
Hi Paul,
Here is the debug.log :
2016-03-07 20:44:52.215 5664 b2.24.2.5 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2016-03-07 20:44:52.216 5664 b2.24.2.5 +++++ Plugin started.
2016-03-07 20:44:57.107 5664 b2.24.2.5 +++++ Plugin running.
2016-03-07 20:45:31.011 5664 b2.24.2.5 Device 0 active is 0
2016-03-07 20:45:31.012 5664 b2.24.2.5 Device 0 priority is 0
2016-03-07 20:45:31.012 5664 b2.24.2.5 Device 0 active is 0
2016-03-07 20:45:31.012 5664 b2.24.2.5 Setting device 0 active to 1
2016-03-07 20:45:31.021 5664 b2.24.2.5 Device 1 priority is 1
2016-03-07 20:45:31.021 5664 b2.24.2.5 Device 0 active is 0
2016-03-07 20:45:31.022 5664 b2.24.2.5 Device 2 priority is 2
2016-03-07 20:45:31.022 5664 b2.24.2.5 Device 0 active is 0
2016-03-07 20:45:31.317 5664 b2.24.2.5 Setting device 0 active to 0
2016-03-07 20:45:31.317 5664 b2.24.2.5 Device 3 priority is 3
2016-03-07 20:45:31.317 5664 b2.24.2.5 Device 0 active is 0
2016-03-07 20:45:31.318 5664 b2.24.2.5 Device 4 priority is 4
2016-03-07 20:45:31.318 5664 b2.24.2.5 Device 0 active is 0
2016-03-07 20:45:31.318 5664 b2.24.2.5 Device 5 priority is 5
2016-03-07 20:45:31.319 5664 b2.24.2.5 Device 0 active is 0
2016-03-07 20:45:31.319 5664 b2.24.2.5 Device 6 priority is 6
2016-03-07 20:45:31.320 5664 b2.24.2.5 Setting device 0 active to 1
2016-03-07 20:45:31.326 5664 b2.24.2.5 Device 7 priority is 7
2016-03-07 20:45:31.328 5664 b2.24.2.5 Saving device configuration
2016-03-07 20:47:01.101 5664 b2.24.2.5 +++++ Plugin ended.
2016-03-07 20:47:01.101 5664 b2.24.2.5 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
And something strange after I apply Configuration :
Note that 3 GPU selected, note that "2" GPU indicated at the viewport but 4 temperatures.
And note that 4 GPU are working on the monitor.
I7-3930K 64Go RAM Win8.1pro , main 3 titans + 780Ti
Xeon 2696V3 64Go RAM Win8.1/win10/win7, 2x 1080Ti + 3x 980Ti + 2x Titan Black
itou31, can you pls run the same test again with the plugin update below.
cant find the OOC memory adjustment bar anymore... why or better where is it gone?
This is fixed in the version below.
Following is an installer link for pre-release 3.0.6.15:
3.0.6.15
- Further logging added to determine why all GPU's are not being enabled
- Fixed various OutOfCore Textures issues
https://render.otoy.com/customerdownloa ... _Win64.exe
AlfaseeD
Just a quick post to share that I'm not having big issues with this version of Octane (I always download the latest version) except fireflies with the daylight environment (sun), but it's something that I need to investigate better before submitting a "report" (ps, yes, I'm using all the "tricks" to reduce/remove this issue).
Thanks for the update
gaazsi
with that latest version all cards are activated anytime you open a file. in case of different vram amounts thats ofc not the best solution...
example: i use 1x gtx 970 for playing and doing stuff meanwhile which has just 4gb and 2x 980 ti for rendering in main rig... but now i am always cut down to those 4gb and forced to use ooc memory in case of a picture that needs more than those 4gb of vram. and its slowing down the 970 card aswell
edit: even whit installing last version of the plugin it stays in this messed-up mode now :(
itou31
Here's my tests :
- Setup 3 GPU with V2
- Start DAZ with V3 and render
- Hit "Apply Configuration" (without selecting any GPU)
- Select all 780ti (6 GPU selected) and apply Configuration
And here is the debug.log
2016-03-08 20:00:29.512 6072 b2.24.2.5 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2016-03-08 20:00:29.513 6072 b2.24.2.5 +++++ Plugin started.
2016-03-08 20:00:34.155 6072 b2.24.2.5 +++++ Plugin running.
2016-03-08 20:01:42.454 6072 b2.24.2.5 Device 0 active is 0
2016-03-08 20:01:42.454 6072 b2.24.2.5 Device 0 priority is 0
2016-03-08 20:01:42.455 6072 b2.24.2.5 Setting device 0 active to 1
2016-03-08 20:01:42.465 6072 b2.24.2.5 Device 1 priority is 0
2016-03-08 20:01:42.466 6072 b2.24.2.5 Device 0 active is 1
2016-03-08 20:01:42.466 6072 b2.24.2.5 Device 2 priority is 0
2016-03-08 20:01:42.777 6072 b2.24.2.5 Setting device 0 active to 0
2016-03-08 20:01:42.777 6072 b2.24.2.5 Device 3 priority is 0
2016-03-08 20:01:42.777 6072 b2.24.2.5 Device 0 active is 0
2016-03-08 20:01:42.778 6072 b2.24.2.5 Device 4 priority is 0
2016-03-08 20:01:42.778 6072 b2.24.2.5 Device 0 active is 0
2016-03-08 20:01:42.778 6072 b2.24.2.5 Device 5 priority is 0
2016-03-08 20:01:42.779 6072 b2.24.2.5 Device 6 priority is 0
2016-03-08 20:01:42.779 6072 b2.24.2.5 Device 0 active is 0
2016-03-08 20:01:42.779 6072 b2.24.2.5 Setting device 0 active to 1
2016-03-08 20:01:42.788 6072 b2.24.2.5 Device 7 priority is 0
2016-03-08 20:01:42.789 6072 b2.24.2.5 Saving device configuration
2016-03-08 20:02:25.765 6072 b2.24.2.5 Device 0 active is 1
2016-03-08 20:02:25.908 6072 b2.24.2.5 Setting device 0 active to 0
2016-03-08 20:02:25.908 6072 b2.24.2.5 Device 0 priority is 0
2016-03-08 20:02:25.909 6072 b2.24.2.5 Device 0 active is 0
2016-03-08 20:02:25.909 6072 b2.24.2.5 Setting device 0 active to 1
2016-03-08 20:02:25.916 6072 b2.24.2.5 Device 1 priority is 0
2016-03-08 20:02:25.916 6072 b2.24.2.5 Device 0 active is 1
2016-03-08 20:02:25.917 6072 b2.24.2.5 Device 2 priority is 0
2016-03-08 20:02:25.917 6072 b2.24.2.5 Device 0 active is 1
2016-03-08 20:02:25.917 6072 b2.24.2.5 Device 3 priority is 0
2016-03-08 20:02:25.918 6072 b2.24.2.5 Device 4 priority is 0
2016-03-08 20:02:25.918 6072 b2.24.2.5 Device 0 active is 1
2016-03-08 20:02:25.918 6072 b2.24.2.5 Device 5 priority is 0
2016-03-08 20:02:26.197 6072 b2.24.2.5 Setting device 0 active to 0
2016-03-08 20:02:26.197 6072 b2.24.2.5 Device 6 priority is 0
2016-03-08 20:02:26.197 6072 b2.24.2.5 Device 0 active is 0
2016-03-08 20:02:26.198 6072 b2.24.2.5 Setting device 0 active to 1
2016-03-08 20:02:26.204 6072 b2.24.2.5 Device 7 priority is 0
2016-03-08 20:02:26.206 6072 b2.24.2.5 Saving device configuration
2016-03-08 20:02:48.884 6072 b2.24.2.5 +++++ Plugin ended.
2016-03-08 20:02:48.884 6072 b2.24.2.5 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
Thanks. You can see in the log that the plugin version is 2.24.2.5 - so something is amiss. I will investigate.... Sorry for the hassle on this issue.
Yes, there is definitely a problem with card activation. I am trying to find a solution.
Roeland posted something in this a while back. From memory is is related to a glossy material being too reflective.
itou31
Hi Paul,
Yes I noticed that too (b2.24.2.5). I though that I have a wrong version, checked and see that the debug is issued from the V3. Is there something wrong if I have different version of DAZ and plugin at the same time ? Never have an issue till the V3.0.6.13.
Hi itou31 - I have repackaged the installer again to make sure all the code is for 3.0.6.16 - can you pls re-download and install and test again from https://render.otoy.com/customerdownloa ... _Win64.exe. Make sure you delete the debug.log file prior to clicking the Apply Configuration button. Pls post the resulting debug.log file here.
EDIT: Link removed. I will re-post it in a hour.
EDIT2: Link re-instated.
itou31
I have applied the same steps as above.
2016-03-09 21:23:52.849 8092 b3.0.6.16 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2016-03-09 21:23:52.849 8092 b3.0.6.16 +++++ Plugin started.
2016-03-09 21:23:58.101 8092 b3.0.6.16 +++++ Plugin running.
2016-03-09 21:25:06.496 8092 b3.0.6.16 Device 0 active is 0
2016-03-09 21:25:06.497 8092 b3.0.6.16 Device 0 priority is 0
2016-03-09 21:25:06.497 8092 b3.0.6.16 Device 0 active is 0
2016-03-09 21:25:06.498 8092 b3.0.6.16 Setting device 0 active to 1
2016-03-09 21:25:06.508 8092 b3.0.6.16 Device 1 priority is 0
2016-03-09 21:25:06.508 8092 b3.0.6.16 Device 0 active is 1
2016-03-09 21:25:06.509 8092 b3.0.6.16 Device 2 priority is 0
2016-03-09 21:25:06.509 8092 b3.0.6.16 Device 0 active is 1
2016-03-09 21:25:06.855 8092 b3.0.6.16 Setting device 0 active to 0
2016-03-09 21:25:06.855 8092 b3.0.6.16 Device 3 priority is 0
2016-03-09 21:25:06.855 8092 b3.0.6.16 Device 0 active is 0
2016-03-09 21:25:06.856 8092 b3.0.6.16 Device 4 priority is 0
2016-03-09 21:25:06.856 8092 b3.0.6.16 Device 0 active is 0
2016-03-09 21:25:06.856 8092 b3.0.6.16 Device 5 priority is 0
2016-03-09 21:25:06.857 8092 b3.0.6.16 Device 6 priority is 0
2016-03-09 21:25:06.857 8092 b3.0.6.16 Device 0 active is 0
2016-03-09 21:25:06.857 8092 b3.0.6.16 Setting device 0 active to 1
2016-03-09 21:25:06.863 8092 b3.0.6.16 Device 7 priority is 0
2016-03-09 21:25:06.865 8092 b3.0.6.16 Saving device configuration
2016-03-09 21:25:29.448 8092 b3.0.6.16 Device 0 active is 1
2016-03-09 21:25:29.546 8092 b3.0.6.16 Setting device 0 active to 0
2016-03-09 21:25:29.546 8092 b3.0.6.16 Device 0 priority is 0
2016-03-09 21:25:29.546 8092 b3.0.6.16 Device 0 active is 0
2016-03-09 21:25:29.547 8092 b3.0.6.16 Setting device 0 active to 1
2016-03-09 21:25:29.553 8092 b3.0.6.16 Device 1 priority is 0
2016-03-09 21:25:29.553 8092 b3.0.6.16 Device 0 active is 1
2016-03-09 21:25:29.554 8092 b3.0.6.16 Device 2 priority is 0
2016-03-09 21:25:29.554 8092 b3.0.6.16 Device 0 active is 1
2016-03-09 21:25:29.554 8092 b3.0.6.16 Device 3 priority is 0
2016-03-09 21:25:29.555 8092 b3.0.6.16 Device 0 active is 1
2016-03-09 21:25:29.555 8092 b3.0.6.16 Device 4 priority is 0
2016-03-09 21:25:29.555 8092 b3.0.6.16 Device 5 priority is 0
2016-03-09 21:25:29.556 8092 b3.0.6.16 Device 0 active is 1
2016-03-09 21:25:29.847 8092 b3.0.6.16 Setting device 0 active to 0
2016-03-09 21:25:29.847 8092 b3.0.6.16 Device 6 priority is 0
2016-03-09 21:25:29.847 8092 b3.0.6.16 Device 0 active is 0
2016-03-09 21:25:29.848 8092 b3.0.6.16 Setting device 0 active to 1
2016-03-09 21:25:29.855 8092 b3.0.6.16 Device 7 priority is 0
2016-03-09 21:25:29.857 8092 b3.0.6.16 Saving device configuration
2016-03-09 21:25:55.961 8092 b3.0.6.16 +++++ Plugin ended.
2016-03-09 21:25:55.962 8092 b3.0.6.16 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
I have refresh the installer at the top of this thread with:
3.0.6.16
- Fixed issue where textures from IRay shaders were not being loaded into Octane materials correctly after re-loading a scene
- Fixed issue where not all GPU's were being enabled (problem introduced in 3.0.6.13).
3.0.6.15
3.0.6.14
- Removed the Save as Jpeg Quality slider from the Preferences tab (since it was not used)
- Removed Jpeg from the Animation tab Image Format combo box
- Added logging to determine why all GPU's are not being enabled
Return to “DAZ Studio”
