glass flip-flop reflection
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
uncia
Hi all.
Here we go again.
I don't know is it a bug or a feature...But i love Specular material more and more.
Just changed "Plane Orientation" from +X to -X.
glass_flip_flop_reflection.rar
(566.25 KiB) Downloaded 271 times
It's expected. Needs normals which are pointed toward out of volume.
Don't use planes, use boxes if you want exact same glass effect.
uncia
What a you talking about ? Volume object ?
This is not a volume it's a simple 4-point polygon plane with glass material.
Download scene file please.
Other renders don't have this problem (i-ray,c4d render,arnold render)
Yambo
glass need to have a volume in order to look like a glass.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
uncia
Yambo wrote:glass need to have a volume in order to look like a glass.
Thank you. I know it.
The post is not about it.
Ok can you please ask in general forums? That's not about plugins.
uncia
Thank you for response. The problem is not related to plugin or Octane.
It's a C4D problem of screwing up Normal direction of polygon when using "Plane Orientation".
I just was surprised that other renders can handle it easy without artifacts.
So apology for a harsh post.
I don't think there's a bug or problem on plugin. It just normalizes the normals how you tweaked.
I want to go even further, for me it's a feature, we can have negative volumes, air volumes inside fog volumes, infinite water planes and optical simulations thanks to this "feature", just to give some examples ;)
If you don't need this, just use a glossy with falloff opacity.
ciao beppe
Return to “Bug Reports”
